727 HELP!!!!!!!!! #1285523
08/14/12 09:51 PM
08/14/12 09:51 PM
NC
rj72cuda Offline OP
rj72cuda  Offline OP
NC
this is the 727 in my lil red express im at a loss and Hate to pay a mechanic when i proally screwed it up so here goes.
I needed a new trans gasket a month ago so i got one and filter while i was there. Trans has 40k miles and never been touched so i assumed i should go ahead and adjust the bands. followed the process "tightened adjuster down to 72 inch Lb then backed off 2 full turns. for both the 1-2 and R-3 adjustments. put the new filter in new gasket sealed the pan on and filled with fluid. no major issue. until i start to pull the truck out and it acts as if my parking brake is LOCKED down. i try forward gears same deal engine revs to 3500 rpm to even get moving and then it still feels like the brakes are holding. I checked all 4 corners for heat and even pushed the truck in Neutral to double check. i have since repeated the process double checking to make sure i did not over tighten when setting the lock nuts
I NEED HELP guys
Re: 727 HELP!!!!!!!!! [Re: rj72cuda] #1285524
08/15/12 09:37 AM
08/15/12 09:37 AM
Weatherford Texas
Greg Ducato Offline
Greg Ducato  Offline
Weatherford Texas
Make sure the fluid level is correct, loosen the front band lock nut , tighten the center bolt down while holding the lock nut till it is "snug", back it off 2 1/4 turns and whle holding it, lock the oter lock nut down. It sounds like the front band is too tight, the rear band should be set at 2 1/2 turns. Fluid was checked in neutral, engine running, yes?
Re: 727 HELP!!!!!!!!! [Re: rj72cuda] #1285525
08/15/12 10:34 AM
08/15/12 10:34 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re adjust the bands most torque wrenches at 72 inch pounds tighten the band a good turn to a turn and 1/2 too tight!
SO start with the kickdown band as it's out where you can get at it.
NOW loosen it off and tighten in with 5/16 wrench just to wrist snug then back it off 2 turns. tighten lock nut being sure you don't turn it in as nut tightens.
Then try it if still tight off comes the pan and same on rear band but back off 2 1/2 turns!
DO NOT TRY TO DRIVE IN THE MEAN TIME!!!
Re: 727 HELP!!!!!!!!! [Re: rj72cuda] #1285526
08/15/12 05:51 PM
08/15/12 05:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you started the engine in Park instead of Neutral after the fluid change the converter isn't full, let it idle in Neutral for awhile and recheck the fluid level when warm and in Neutral.
Re: 727 HELP!!!!!!!!! [Re: rj72cuda] #1285527
08/19/12 10:35 AM
08/19/12 10:35 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Any updates??
Re: 727 HELP!!!!!!!!! [Re: Dodgem] #1285528
08/19/12 05:55 PM
08/19/12 05:55 PM
NC
rj72cuda Offline OP
rj72cuda  Offline OP
NC
re adjusted front band, made a big improvement still not "right" but better looks like off withthe pan and adjusting that as well after a trip to the store for MORE trans fluid
Re: 727 HELP!!!!!!!!! [Re: rj72cuda] #1285529
08/20/12 12:24 AM
08/20/12 12:24 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
We all bin there :-) well lots of us good luck. don't know what it is but every inch pound torque wrench I've tried tighted bands way to tight
I was once told the only ones that work well on low inch pounds are the needle type??
Re: 727 HELP!!!!!!!!! [Re: Dodgem] #1285530
08/20/12 08:24 PM
08/20/12 08:24 PM
NC
rj72cuda Offline OP
rj72cuda  Offline OP
NC
Im just going with way looser than it calls for hope it works
Re: 727 HELP!!!!!!!!! [Re: rj72cuda] #1285531
08/20/12 09:25 PM
08/20/12 09:25 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
wrist snug and 1 1/2 to 2 turns front wrist snug and 2 to 2 1/2 turns rear!
