MP 528 crate Hemi block coolant blockage? #1285083
08/14/12 12:34 AM
08/14/12 12:34 AM
canada
marfen Offline OP
marfen  Offline OP
canada
Wondering if anyone else has 528 MP crate hemi cooling issues due to excessive casting crap in the water jackets right behind the water pump ports. A buddy couldn't get his 528 to run cool until Barton's mentioned seeing this problem a couple of times. Sure enough that was the problem with his and I'm checking mine as well since my 528 gets hot real quick as well despite new big rad, etc.
Re: MP 528 crate Hemi block coolant blockage? [Re: marfen] #1285084
08/15/12 12:15 AM
08/15/12 12:15 AM
canada
marfen Offline OP
marfen  Offline OP
canada
here are some pics inside the lower waterpump block ports of the 528 MP crate and inside the same lower waterpump holes in a 66 cast 426. Guess I know why the 528 gets hot so quick. Now what do i do?
Re: MP 528 crate Hemi block coolant blockage? [Re: marfen] #1285085
08/15/12 12:16 AM
08/15/12 12:16 AM
canada
marfen Offline OP
marfen  Offline OP
canada
previous one was lower LH water port on 528 hemi engine. this one is the lower RH 528
Re: MP 528 crate Hemi block coolant blockage? [Re: marfen] #1285086
08/15/12 12:17 AM
08/15/12 12:17 AM
canada
marfen Offline OP
marfen  Offline OP
canada
here's 66 426 lower LH waterport
Re: MP 528 crate Hemi block coolant blockage? [Re: marfen] #1285087
08/15/12 12:20 AM
08/15/12 12:20 AM
canada
marfen Offline OP
marfen  Offline OP
canada
here's 426 lower rh waterport. you can clearly see the cylinders and far into the block. on the 528 you really can't see past the slag...any ideas how to deal with the 528 would be greatly appreciated
Re: MP 528 crate Hemi block coolant blockage? [Re: marfen] #1285088
08/15/12 08:54 PM
08/15/12 08:54 PM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
You can clean it up with a deburring tool. Just be careful not to hit a cylinder or any machined surfaces
Re: MP 528 crate Hemi block coolant blockage? [Re: marfen] #1285089
08/15/12 10:01 PM
08/15/12 10:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are you the original buyer of the engine and how long ago ?
Re: MP 528 crate Hemi block coolant blockage? [Re: JohnRR] #1285090
08/15/12 10:30 PM
08/15/12 10:30 PM
canada
marfen Offline OP
marfen  Offline OP
canada
I bought it new in march 09. it has @ 5 miles on it, it's one built @ Bartons shop for Mopar Performance. thanks for the pointers folks, much appreciated.
Re: MP 528 crate Hemi block coolant blockage? [Re: marfen] #1285091
08/16/12 10:05 AM
08/16/12 10:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mopar banks on this, buy it and get it running long after the 90 day warranty expires.
Barton should be checking for this when he is assembling them and rejecting, or fixing, the blocks before he assembles them. It should have gotten real hot during the dyno seesions one would think and given him a heads up ???
You might try to see what Mopar will do for you if you can't clear it, but I wouldn't hold your breath.
Re: MP 528 crate Hemi block coolant blockage? [Re: JohnRR] #1285092
08/16/12 12:22 PM
08/16/12 12:22 PM
canada
marfen Offline OP
marfen  Offline OP
canada
I sure never thought to check it and I'm thinking it wouldn't have got hot enough on the dyno @ Ray's for the problem to reveal itself...motor would've been warmed up, done it's pull, and shutdown...attention to detail on this MP/barton built 528 is impressive. Block manufacturer is the one laying down here IMHO.
Re: MP 528 crate Hemi block coolant blockage? [Re: marfen] #1285093
08/16/12 01:55 PM
08/16/12 01:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I guess the next question is what is HOT and is your cooling system up to the task ? 5 miles isn't much to gauge the extent of the issue .
Barton can be hit or miss a friend had him do an engine , had to take it back twice.
Re: MP 528 crate Hemi block coolant blockage? [Re: marfen] #1285094
08/16/12 05:13 PM
08/16/12 05:13 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
When I opened this I thought this would be the issue with the hole running into the deck from the WP not being machined all the way through, which only the earliest blocks had. Should have been cleaned up by '09 though.
You didn't need to know that, but I just wanted to be honest because I am very familiar with that issue/seen it a bunch of times, but I've never seen quite that much casting flash in the lower holes
I'm with Scott, and I would want to clean that up but proceed with extreme caution.
Rich H.
Esse Quam Videri
Re: MP 528 crate Hemi block coolant blockage? [Re: ZIPPY] #1285095
09/22/12 10:14 AM
09/22/12 10:14 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Are these the world blocks? Will the siamese casting make problems?
Thanks!
Re: MP 528 crate Hemi block coolant blockage? [Re: Oyvind Mopar] #1285096
02/15/13 12:19 PM
02/15/13 12:19 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Why has this issue been hushed up? Did world step up and take responsibility or their defective castings? Enquiring minds wan to know... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: MP 528 crate Hemi block coolant blockage? [Re: Oyvind Mopar] #1285097
02/15/13 03:13 PM
02/15/13 03:13 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Thanks!
I had it in my world siamese block, fixed in about 5 minutes. 4 of those was finding a hole saw to clean up the port. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
