Dana Pinion Nut Loosened after 4 years???
#1285017
08/13/12 10:24 PM
08/13/12 10:24 PM
Posts: 1,443 Maryland
Dads426
Maryland
Went to Beaver Springs last weekend and after going a few rounds the car developed a vibration after letting off at the finish line. Got worse the next run (we lost anyway), so we put it away and checked it at home (didn't notice anything out of the ordinary at the track, but knew something was wrong). Got it home and pulled the driveshaft (it was OK) but found the pinion nut loose. It has been on there for 4 years with no problems, but the nut had no crush left as a locknut. Oil, gears and bearings look and feel good. Should I clean the treads use oil on the face of the washer and nut, and loctite red on the threads or buy a new locknut and use loctite for a little extra insurance? Any reason why this thing loosened (I used the Mancini pinion locking tool and a BF breaker bar to tighten it when I set it up). As you may recall, we were having problems with tire shake and I'm wondering if that caused it to loosen. Thanks for the help ![](/ubbthreads/images/graemlins/bow.gif)
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
Re: Dana Pinion Nut Loosened after 4 years???
[Re: Dads426]
#1285018
08/13/12 10:32 PM
08/13/12 10:32 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Thanks for the help
I would check the U joints and pay a driveshaft shop to make sure the shaft is properly balanced. Get a new nut and use loctite red for extra insurance. Some guys like to stake the nut, which is effective, but then you will likely do damage to the threads when you take it apart. I dont stake the nut and have never had a problem and I build a fair amount of D60's.
MB
[Re: HPMike]
#1285019
08/13/12 10:46 PM
08/13/12 10:46 PM
Dads426
Maryland
Thanks. Driveshaft is a chrome-moly unit and u-joints are free with no play. You can drive this car at 135 mph with one arm out the window and a finger on the wheel it is so smooth.
