90 Degree Oil Filter Adapter - Which One To Use? #1285008
08/13/12 09:57 PM
08/13/12 09:57 PM
Kansas
Menzaero Offline OP
Menzaero  Offline OP
Kansas
I have two; one aluminum and one steel. I just removed the steel one because it was leaking at the bolt head. I have a new gasket set ordered. Here is the deal; the aluminum adapter has a bolt with a 1-3/16" head but the inside diameter of the hollow bolt appears smaller than the bolt that came with the steel adapter which has a 3/4" head bolt. The larger head bolt has holes and the smaller head bolt has slots for oil flow.
I plan on using the aluminum adapter; does it make sense to use the 3/4" head bolt or do I need to stick with the 1-3/16" bolt that came on the aluminum adapter?
Thanks-
Re: 90 Degree Oil Filter Adapter - Which One To Use? [Re: Menzaero] #1285009
08/13/12 11:14 PM
08/13/12 11:14 PM
Kansas
Menzaero Offline OP
Menzaero  Offline OP
Kansas
Bolt head size comparison-
Re: 90 Degree Oil Filter Adapter - Which One To Use? [Re: Menzaero] #1285010
08/14/12 01:03 AM
08/14/12 01:03 AM
In a racing app pick the one that flows the most. You can add holes in the shank of the bolt & port the sharp edges in the adapter
Re: 90 Degree Oil Filter Adapter - Which One To Use? [Re: RapidRobert] #1285011
08/14/12 01:29 PM
08/14/12 01:29 PM
dogdays Offline
dogdays  Offline
It really doesn't matter. That's the real answer. The extra friction loss caused by the slightly smaller diameter won't even be 1/10 of a psi because of the very short length.
Also, this is on the pressure side of the pump. If it was on the suction side you'd use the larger one.
If I could get you guys to understand Bernoulli's equation for fluid flow you could approach a problem like this with some knowledge. Basically, the equation says that any liquid has a certain amount of energy. It can be in the form of pressure, velocity or height above the datum or zero line. I can't remember if temperature is included but I think it is. The fluid can transfer one kind of energy into another and back, taking into account losses. So the oil has a certain velocity, pressure and height. In this application we can disregard height and concentrate on velocity and pressure. The oil transfers some of its pressure energy into velocity energy as it goes through the smaller diameter section of pipe, but when it gets to the other end and velocity slows down, most of that energy transfers back into pressure.
It seems that most people think of fluid flow as toothpaste squeezed out of a tube, that it stays the same diameter and if it has to go through a smaller diameter, less goes through, but this is wrong. Bernoulli's equation describes the reason why it works that way.
End of lecture.
R.
