Dana 60 Axle Tube Question? #1284776
08/13/12 08:31 PM
08/13/12 08:31 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Bought a "newly" done Dana with new tubes. Its leaking lube out holes for the case - spreader.
Isn`t the press fit of the tube into the housing supposed to be clean and tight enough to seal?
Outside of a poor fit what else could it be???
Time for a REFUND
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Dana 60 Axle Tube Question? [Re: 6bblFLASH] #1284777
08/14/12 04:00 AM
08/14/12 04:00 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Time for a REFUND
Should be tight enough to seal but sometimes they don't, I would clean it really well and mix up some JB weld and put a thin coat down in the very bottom corner of the hole, just enough to fill in the corner slightly but not enough to not use a spreader if you ever need to, or weld it,which I don't reccomend because of not ever being able to use a spreader if you ever need to.
Re: Dana 60 Axle Tube Question? [Re: 6bblFLASH] #1284778
08/14/12 12:55 PM
08/14/12 12:55 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I would think it should be welded, if its leaking it could spin under a launch, mine are welded and it doesnt leak.
Re: Dana 60 Axle Tube Question? [Re: 70blackfish] #1284779
08/14/12 01:04 PM
08/14/12 01:04 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
the tubes to the housing definately yes, but my understanding is, it is the hole's in the casting where you put the case spreader thats leaking, you normally don't weld those because you wouldn't be able to use the spreader.jmo
Re: Dana 60 Axle Tube Question? [Re: dartman366] #1284780
08/14/12 06:56 PM
08/14/12 06:56 PM
N.E. Ohio
N.E. Ohio
Picture,they started to weld the hole shut. So now I will bore it outthen fix the leak.
Seriously------------ can you buy ANYTHING thats done right????
Re: Dana 60 Axle Tube Question? [Re: 6bblFLASH] #1284781
08/14/12 06:57 PM
08/14/12 06:57 PM
N.E. Ohio
N.E. Ohio
#2
Re: Dana 60 Axle Tube Question? [Re: 6bblFLASH] #1284782
08/14/12 08:09 PM
08/14/12 08:09 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
OH, i see
Re: Dana 60 Axle Tube Question? [Re: 70blackfish] #1284783
08/14/12 08:12 PM
08/14/12 08:12 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Where did that beauty come from?
Re: Dana 60 Axle Tube Question? [Re: Jeremiah] #1284784
08/14/12 09:29 PM
08/14/12 09:29 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
That hole is supposed to be welded up...the housing to the tube....appears the tubes may be welded also.....just smear a tad bit of silicone and call it a day.....glad I don't have to please you.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Dana 60 Axle Tube Question? [Re: instigator] #1284785
08/14/12 09:37 PM
08/14/12 09:37 PM
N.E. Ohio
N.E. Ohio
REALLY?????
YOU weld the case-spreader holes SHUT????
Glad I did`nt get it from you either
Re: Dana 60 Axle Tube Question? [Re: 6bblFLASH] #1284786
08/15/12 03:41 PM
08/15/12 03:41 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I recently built a Dana 60 for my Ramcharger and I started by welding the tubes to the carrier housing with 7018 rod, then the perches to the tubes(again with 7018) and finally a 4X4 shop jig welded the new ends to the tubes with "Dual Shield MIG". I have never had leaks from the case spreader holes, but have had leaks from the tubes on an OEM Dana in the old race car ('68 Coronet). I have always done my Dana work without a case spreader, but have always been concerned when putting the carrier back in (with the BFH) about damaging the new bearings. I recently found an OTC case spreader on CL for $150.00 and snapped it up. I think your best move is to clean the holes with a small wire wheel and plug them with silicone, then if you need to service the rear end it would be easy to pull the plug and attach the spreader.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Dana 60 Axle Tube Question? [Re: Polarapete] #1284787
08/16/12 12:56 AM
08/16/12 12:56 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Do you have a vent on the housing? Sounds like its building preasure. Make sure the right amount of oil.
Re: Dana 60 Axle Tube Question? [Re: 6bblFLASH] #1284788
08/16/12 01:19 AM
08/16/12 01:19 AM
bigbee Offline
bigbee  Offline
I think, as others, if you vent the housing (as it should be), and apply some silicone in the holes it shouldn't leak. I have a vent, and mine doesn't leak without silicone. You can always pull out the silicone if you need to use a case spreader.
Re: Dana 60 Axle Tube Question? [Re: cudaman1969] #1284789
08/16/12 06:55 AM
08/16/12 06:55 AM
N.E. Ohio
N.E. Ohio
Good piont ,but its never been in the car yet.
Started leaking unloading it from the truck
