I have a question about the seat track release cable used on the 71 b-body bucket seats. Are they the same length on both the drivers seat and the passenger seat ? Also do they both use the same 1/2" wide by 4"long formed/bent metal plate to hold tension on the cable ? My drivers seat cable is broken and half missing. Also there is no formed/bent metal bracket under the seat so I do not know if there should be one.
I forgot to mention the cable on the passenger side is 13" long. Aftermarket cables are 11" & 13 " .
