Pre 65 8 3/4 vs new style...what fits #1284729
08/13/12 07:07 PM
08/13/12 07:07 PM
Harleysville, PA USA
Tommy D Offline OP
Tommy D  Offline OP
I have a 64 Plymouth Fury I'm working on. It originally came with a trunion style 8 3/4 rear. The one with the bolt in the end of the axles. I want to switch to a new style 8 3/4 and was wondering if I can swap the guts of a new rear into the old housing. Will the parts fit or do I need to use the new style housing with new style internals? Thanks for the help. TD
Re: Pre 65 8 3/4 vs new style...what fits [Re: Tommy D] #1284730
08/13/12 07:22 PM
08/13/12 07:22 PM
dogdays Offline
dogdays  Offline
Swap in a '65 axle. There are length differences. Or get a custom set of axles for your '64 housing.
R.
Re: Pre 65 8 3/4 vs new style...what fits [Re: dogdays] #1284731
08/13/12 07:52 PM
08/13/12 07:52 PM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
Your center section will work but your axles will be too long.
Re: Pre 65 8 3/4 vs new style...what fits [Re: Max Wedge Savoy] #1284732
08/14/12 04:01 AM
08/14/12 04:01 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I used a complete 65 axle assembly in my 63 and it fit just right. 8-3/4 of course. Ron
Re: Pre 65 8 3/4 vs new style...what fits [Re: 383man] #1284733
08/14/12 06:42 AM
08/14/12 06:42 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You can use aftermarket shafts(good upgrade anyway). If the green style bearings (non tapered) are used, the shafts will fit. There's only one difference between the housings besides length. The in area for the seal is not deep enough in the axle tube to take a seal and a standard bearing. The green bearing does not require the housing seal. I have done this a few times with good results.
Doug
Re: Pre 65 8 3/4 vs new style...what fits [Re: dvw] #1284734
08/14/12 08:27 AM
08/14/12 08:27 AM
Tommy D Offline OP
Tommy D  Offline OP
Thanks for the responses. Looks like I'll use the old housing with new axles and green bearings. Tom
Re: Pre 65 8 3/4 vs new style...what fits [Re: Tommy D] #1284735
08/14/12 11:06 AM
08/14/12 11:06 AM
Az
Crizila Offline
Crizila  Offline
Az
October issue of Car Craft has got a pretty good article on 8 3/4"s that might help you out some.
Fastest 300
Re: Pre 65 8 3/4 vs new style...what fits [Re: Tommy D] #1284736
08/14/12 01:37 PM
08/14/12 01:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I believe Doc Diff has the conversion axles in stock.
Re: Pre 65 8 3/4 vs new style...what fits [Re: John_Kunkel] #1284737
08/14/12 02:10 PM
08/14/12 02:10 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Isn't the housing end bolt pattern slightly different between the earlier and 65+ stuff?
The splined axle housing I had was different.
Re: Pre 65 8 3/4 vs new style...what fits [Re: John_Kunkel] #1284738
08/14/12 02:19 PM
08/14/12 02:19 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I talked with him at the Nats about this same topic.
Re: Pre 65 8 3/4 vs new style...what fits [Re: pushbutton] #1284739
08/14/12 06:42 PM
08/14/12 06:42 PM
Tommy D Offline OP
Tommy D  Offline OP
Thanks for all the help. Dr. Diff will get a call. TD
