1970 4 spd gearshift column interlock? #1284719
08/13/12 06:21 PM
08/13/12 06:21 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
What did this do, and why are they not on 1971 cars? Thanks.
Re: 1970 4 spd gearshift column interlock? [Re: ragtop] #1284720
08/13/12 07:02 PM
08/13/12 07:02 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
70 was the first year for a locking column. It requires you to put the car in reverse which locks the column and allows you to remove the key. 71 had the lever on the column which locked the column.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
