Re: Six pack Set up
[Re: RStoner]
#1284694
08/13/12 05:28 PM
08/13/12 05:28 PM
Posts: 1,105 Ont, Canada
moparo
Ont, Canada
What is the build date on your motor? The 426 date is not an accurate date.
performancecarrestorations.com
Re: Six pack Set up
[Re: RStoner]
#1284696
08/13/12 06:12 PM
08/13/12 06:12 PM
Posts: 17,529 Las Vegas, NV
6bblgt
Las Vegas, NV
'69 A12 cars have a SPD (scheduled production date) of 329 or 426. The cars were actually built from mid-March 'til June. Here's a recent thread transmission date code? that gets into determining actual build dates from other info/dates that can be found on your car. If you have the original fender tag, post the top line info & we can get you the most accurate date available.
Re: Six pack Set up
[Re: RStoner]
#1284698
08/13/12 06:31 PM
08/13/12 06:31 PM
moparo
Ont, Canada
i can check my A12 it is matching #s. What is the vin on yours? PM me if you don't want to post it.
Re: Six pack Set up
[Re: moparo]
#1284699
08/13/12 06:53 PM
08/13/12 06:53 PM
6bblgt
Las Vegas, NV
From that info - educated guess - RM23M9A2625xx Actual in plant SPD of Monday, April 28, 1969 Probably built on Thursday, May 1, 1969 If you have your original K-frame, it should have a date around 4/30-5/1 in the format: 1209 1 OR 1219 1. edit
Re: Six pack Set up
[Re: RStoner]
#1284700
08/13/12 07:06 PM
08/13/12 07:06 PM
6bblgt
Las Vegas, NV
..... back to your original question - the intake: look for the "goofy" 6 in the part number. ![](/ubbthreads/images/graemlins/scope.gif) here's a MOPARTS ![](/ubbthreads/images/graemlins/thumbs.gif) post with pictures. The carb numbers you posted are for '69 440 4-spd cars with 0929 (Wed. 4/2/69), 1019 (Fri. 4/11/69), & 1209 (Wed. 4/30/69) dates. They sound to be almost "perfect" for your car.
Re: Six pack Set up
[Re: RStoner]
#1284701
08/13/12 07:10 PM
08/13/12 07:10 PM
Posts: 21,554 N.E. OHIO, USA
A12
N.E. OHIO, USA
the 046 is the correct part number for a '69 A12 Edelbrock aluminum intake manifold and the carbs are the correct part numbers and date range for an A12 with a second batch 4-26 Scheduled Production Date (SPD) is there anything odd on the intake manifold 046 part number that you see ![](/ubbthreads/images/graemlins/whistling.gif) Oops I see that was pointed out.. ![](/ubbthreads/images/graemlins/blush.gif)
Re: Six pack Set up
[Re: RStoner]
#1284704
08/13/12 07:33 PM
08/13/12 07:33 PM
A12
N.E. OHIO, USA
Dan,
Thanks for the info. Had this car since Dec. 1970. Being a dumb a-- kid traded original six pack engine and carbs for a Hemi. Changed K frame and a few wrecks later,ect.ect., you have heard this story before. Anyhow, kept car all these years, and trying to get parts together for a someday rebuild. Sounds like these carbs and manifold would be correct for this car. I wish the air cleaner was correct. Vin. RM23M9A2625xx
Randy
Randy, you for sure have to go here: http://a12mopar.com/yabb/YaBB.pl and here: http://sixpacksixbbl.homestead.com/index.html and share a few stories or two ![](/ubbthreads/images/graemlins/beer.gif)
MikeR
Re: Six pack Set up
[Re: bigcountry]
#1284706
08/14/12 01:45 AM
08/14/12 01:45 AM
6bblgt
Las Vegas, NV
6bblgt can you give me a build date on my A12...28111 312487 9A307000. Thanks and take care, B.C..
Best guess - WM23M9A307000 - "Holy late M-code Batman" ![](/ubbthreads/images/graemlins/shock.gif) In plant SPD of Tuesday, July 8, 1969 Probably built on Thursday, July 10, 1969
Being that was the last week of "scheduled production", it may have been built even later. End of the model year & everything, I believe "schedules" weren't running like clockwork. 312487 (fender tag body sequence number) - 307000 (assigned VIN sequence number) = 5487 units "LATE"; during normal 1969 Lynch Rd. production that would be approximately 5+ days late (not 2 ). I wonder if there were "blocks" of "sales bank cars" with assigned VIN#s that were available for end-of-year build outs, but never got built. ![](/ubbthreads/images/graemlins/shruggy.gif)
What components do you have with additional date help: engine, K-frame, b'cast? VON#?
Re: Six pack Set up
[Re: bigcountry]
#1284707
08/14/12 03:02 AM
08/14/12 03:02 AM
A12
N.E. OHIO, USA
If you registered that A12 road runner it would be the last or highest VIN on there as an A12 runner and right before this one that appears to be nine from the end of the A12 Bee's if the XXXXXX VIN's are really higher?
http://regcars.homestead.com/Car465.html
The last registered A12 runner...would be nice if you put it on the A12 Registry
Re: Six pack Set up
[Re: 6bblgt]
#1284709
08/14/12 04:01 AM
08/14/12 04:01 AM
A12
N.E. OHIO, USA
I don't "chase" the A12s like others, but the highest M-code VIN#s I have are:
RM21M9A294953 (early June) WM23M9A309928 (early July)
Been "chasing" them since the 90's and because of the two batch 3-29 and 4-26 SPD's it's nice to try and narrow down when an A12 "may" have come down the assembly line...still no guaranty when it was finished but kind of can guess a little on when the body may have rolled down most of the line.
