I am fabbing up the crossmember for my four speed. Car is a 65 coronet, with a 67 coronet K frame, so some fab work is needed.
Its been along time since I had a 4 speed in any mopar let alone this set up. Seems like the tail shaft is over towards the passenger side. I have the trans way up in the tunnel right now, and it gives a better idea of how much it is moved over. Since I am fabbing the crossmember, and my original isnt anywhere near close enough to tell, I am not sure if this slight issue is normal or not.
I believe my motor mounts are in correct, and the K frame is in correct.
It looks alot closer ( to the proper location) when the trans is at the proper height
Thoughts?
