holley 4150 float bowl inlet stripped, any options?
#1284506
08/13/12 11:27 AM
08/13/12 11:27 AM
Posts: 697 Central IL
70Sbird
Central IL
Any options besides replacing it? I don't know if there is such a thing as a repair insert (I have seen this done before, but not in a kit form for home use) or other repairs? ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: holley 4150 float bowl inlet stripped, any options?
[Re: Dodgem]
#1284509
08/13/12 02:22 PM
08/13/12 02:22 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
If thats a stock Mopar Holley I probally have one.Took apart one from my 70 Imp.That carb should have the transfer tube between the frt and rear bowls.Rocky
Chrysler Firepower
[Re: therocks]
#1284510
08/13/12 02:29 PM
08/13/12 02:29 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I don't think any Holley with center hung floats used a transfer tube. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: dogdays]
#1284513
08/13/12 09:16 PM
08/13/12 09:16 PM
62maxwgn
Blair County,PA
The Helicoil kit will do about 10 bowls and costs around $70. JB Weld costs about $5.00 and will get the job done for you. Plus, it'll be ready to roll in 24 hours. That's what I'd be doing.
R.
That kit is for the fuel bowl screws,OP has stripped fuel inlet fitting threads.
[Re: 62maxwgn]
#1284514
08/13/12 10:28 PM
08/13/12 10:28 PM
70Sbird
Central IL
R.
Exactly, good catch 62Max! I would consider the JB weld in there but this is also where the filter(s) reside - behind this fitting, so if I used JB weld I would have to ditch the filter
