48 dodge #1284154
08/12/12 06:56 PM
08/12/12 06:56 PM
Brandon, Manitoba, Canada
Roadripper Offline OP
just bought a 48 dodge 4r it has no wheels on it was wondering what bolt pattern the hubs are and what would fit any help would be great thanks mike
Re: 48 dodge [Re: Roadripper] #1284155
08/13/12 09:55 AM
08/13/12 09:55 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
My 54 was 5x4.5" with tapered shoulder bolts instead of studs.
Re: 48 dodge [Re: radar] #1284156
08/13/12 11:15 AM
08/13/12 11:15 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
my 38 Plymouth and 40 Chrysler were also 5 on 4.5" with tapered bolts instead of studs. They also had an alignment pin to guide the rim as you were bolting it up. I've used later Mopar rims on them with drilling the hole for the pin as needed. Or you can pull the pin out. Rock auto sells the bolts.
Don't be the exception.
Re: 48 dodge [Re: Supercuda] #1284157
08/13/12 12:16 PM
08/13/12 12:16 PM
dogdays Offline
dogdays  Offline
it is 5 on 4.5, easy fit.
Have you made your presence known in the Streetrods section?
R.
Re: 48 dodge [Re: dogdays] #1284158
08/13/12 12:58 PM
08/13/12 12:58 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Yep, 5 on 4.5.
Left hand on left side, start looking NOW for left hand lug bolts.
Also as mentioned, there is a pin that must be taken into account. Try to avoid just knocking it in and having it foul the brakes!
Check out the P-15 D-24 site for a lot more info.
