Re: Difference between 10.5 and 11.0 cr
[Re: Ian]
#1283146
08/11/12 10:37 PM
08/11/12 10:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
what is your complete combo/weight .your 2 tenths may be in advancing cam ,gear change ,stall etc
Yes... advancing the cam a few degrees might give him the same cyl pressure as using the thinner gasket... if he has the piston to valve clearance... also the cam advanced would increase in torque on the low end so that is a plus
