Re: Difference between 10.5 and 11.0 cr [Re: Ian] #1283146
08/11/12 10:37 PM
08/11/12 10:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
what is your complete combo/weight .your 2 tenths may be in advancing cam ,gear change ,stall etc
Yes... advancing the cam a few degrees might give him
the same cyl pressure as using the thinner gasket...
if he has the piston to valve clearance... also the
cam advanced would increase in torque on the low end
so that is a plus
Re: Difference between 10.5 and 11.0 cr [Re: MR_P_BODY] #1283147
08/11/12 10:55 PM
08/11/12 10:55 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
If your considering a head gasket change look @ the size of the gasket bore compared to the engine bore, If you have any dead space in a larger gasket bore you can find some more cyl pressure there
Re: Difference between 10.5 and 11.0 cr [Re: emarine01] #1283148
08/12/12 12:14 AM
08/12/12 12:14 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
As a couple of us have said now,if your quench needs fixed it will help some. Maybe not a full 2 tenths though.
Combine that with a few other things,depending on how sorted out the car is and yoyo can get it. I would think that cam would probably be happiest in at 106 if I were to guess based on the cam/ compression and what you have given us.
Keith
Re: Difference between 10.5 and 11.0 cr [Re: Dunnuck Racing] #1283149
08/12/12 12:52 AM
08/12/12 12:52 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Thanks for all the help guys...I have my answer
Dan
Re: Difference between 10.5 and 11.0 cr [Re: Wedgeman] #1283150
08/12/12 11:51 AM
08/12/12 11:51 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
I can advance timing 4* by changing the timing gear slots.....would it be ok ?
I already have lots of top end power, doing so is supposed to give more low end torque and cyl presuure....so I read
Dan
