Re: .035" Quench for steel-rod big block...
[Re: BradH]
#1282849
08/10/12 12:44 PM
08/10/12 12:44 PM
Posts: 4,213 New York
polyspheric
New York
IIRC Jenkins said that if you don't need more knock suppression tighter clearance increases pumping loss. How much probably varies with the quench surface area and how the edges are prepared.
Boffin Emeritus
[Re: BradH]
#1282850
08/10/12 04:18 PM
08/10/12 04:18 PM
Posts: 2,091 Delray beach, Florida
Performance Only
i don't personally feel there's enough benefit to reduce the quench to .035 vs. .040 thre's most certainly a downside though if the piston starts contacting the head. as the bore and piston wears over time, the piston skirt to wall clearance will increase and hence more piston rock.
machine shop owner and engine builder
[Re: 73outlaw]
#1282856
08/11/12 12:27 AM
08/11/12 12:27 AM
340roadrunner
Just last week buddy of mine gernaded his 451,guess how??!! I pulled it down and it has .030-.035 piston to head clearance,not good now have a pile iron. Never made a pass down the track. WTF was the builder thinkin????? ![](/ubbthreads/images/graemlins/flame.gif) I would say less than 5hp is in .005 keep her north of .040
wow that really sucks for your buddy! Sounds like hes a dork though... can't he tear down his own engine? Next you'll tell me his cars pink or something.. I agree .035 quench is too little.
[Re: BradH]
#1282857
08/11/12 01:25 PM
08/11/12 01:25 PM
Posts: 43,335 Bend,OR USA
Cab_Burge
Brad, rock the pistons both ways and shoot for .039 piston to head for pump gas with .002+ rod bearing clearances ![](/ubbthreads/images/graemlins/Twocents.gif) I have never ran rod bearings tighter than .0025 and I have seen witness marks on my piston edges my pump gas street motor with .003+ rod bearing clearances and .039 piston to head clearances cold on the edges ![](/ubbthreads/images/graemlins/shock.gif) I switched to a set of .042 Cometics MLS ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Performance Only]
#1282861
08/19/12 05:34 PM
08/19/12 05:34 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I just did 2 identical small block stroker builds, first one had 10.2:1 and cam was 241@ .050 hyd and second was 10:1 with same cam. Everything else was the exact same from carb to pan...3HP difference and 7Tq. Yes the 10.2:1 engine made slightly more, but you'd never feel it. The first engine will operate at much higher elevationi than the second hence why the bump in compression.
I agree, .040-.045 will be such a small amount of quench and compression...you'll only see it on the dyno chart.
Brian Hafliger
