trans pan gasket recommendation
#1282800
08/10/12 10:16 AM
08/10/12 10:16 AM
Posts: 847 Parsons (SouthEast) Kansas
funkyjbp
mopar addict
mopar addict
everyone, which is better: cork or rubber? I am installing an A500 OD in my 77 shortbed and i have a new rubber gasket already. Is cork worth buying? thanks! JP in the land of Oz.
71 SWB, 413
77 SWB, 318
92 SWB, 5.2 magnum
79 Macho Short bed, 318
03 stratus coupe R/T
too many others not on the road!
Re: trans pan gasket recommendation
[Re: funkyjbp]
#1282801
08/10/12 10:51 AM
08/10/12 10:51 AM
RapidRobert
reportedly the reinforced pan gasket from MP though pricey is the best way to go
[Re: RapidRobert]
#1282802
08/10/12 11:13 AM
08/10/12 11:13 AM
Posts: 15,487 Florida
scratchnfotraction
I run the newer pan gaskets and use the mopar black ATF/RTV to seal the dip tube and the low/revs pivot pin at the back of the case. 727-2464324ac 904-4295875ac well worth the $ at the dealer make sure to NOT over torque the bolts,the gasket does not compress and will strip the bolt holes out if over torqued.
[Re: RapidRobert]
#1282805
08/12/12 02:21 PM
08/12/12 02:21 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Shop around. You can find them at a reasonable price, even from the dealer. They are worth it. My 904 never leaked a drop, even with no sealant. I had it off later to adjust the bands, reused it and still no leaks.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1282807
08/12/12 03:05 PM
08/12/12 03:05 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
Got mine on ebay for $20 delivered, well worth it!
[Re: funkyjbp]
#1282809
08/14/12 11:28 AM
08/14/12 11:28 AM
Posts: 404 Central New York
bfury
Central New York
Do like the factory does now. They use their ATF/RTV product without a gasket. About $6 a tube at the dealer parts counter. It solved my leak problems after using the new style pan gasket on a 727 that leaked. Probably the trans surface but the RTV solved it.
No Stock
[Re: bfury]
#1282810
08/14/12 04:26 PM
08/14/12 04:26 PM
scratchnfotraction
x2, I used it on all of the gskaets on the 440 engine and trans.
now I only use the copper rtv on the header gaskets,everything else get the mopar black ATF/RTV
I am gonna try it on the headers next time I have them off to see if it will burn..I know the copper rtv will not burn at the cyl port and thats for sure.
[Re: d-150]
#1282811
08/14/12 06:37 PM
08/14/12 06:37 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
i like the rubber pan gasket with steel encased in the rubber. had good luck with them so far
x2
Reused one twice so far on one trans and another reused once so far on another and still not a drop out of either.
