Re: 1970 LAPD Belvedere
[Re: savoy64]
#1282720
08/11/12 10:36 AM
08/11/12 10:36 AM
Posts: 27,595 So Cal
autoxcuda
So Cal
Here's a RK41N1G.....
Are these F codes for heavy duty suspension and or frame? Do they come with every RK police car standard?
N97 Y39 F58 F72 J52 M25 M?? B42 B51 F13 F?38 H51 B51
[Re: autoxcuda]
#1282721
08/11/12 11:18 AM
08/11/12 11:18 AM
Posts: 6,680 Va. Beach, Va
69superbee383
Va. Beach, Va
My first car was a 70 Belvedere police unit. RK VIN. The cars with 383 and AC were non HP units painted blue.
My 69 Superbee factory AC car is also a non hp engine painted turquiose and not orange.
If that care was not 3000 miles away it would be in my driveway. And yes they were basically 4 door RR's. I had mine fitted with a GTX front clip and tailights and had the buckets and center console installed.
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
[Re: stateline]
#1282725
08/11/12 11:55 PM
08/11/12 11:55 PM
Posts: 1,818 NW
hergfest
NW
I don't think this car was LAPD. All of the LAPD cars I have seen have been green, and the axle code on the tag is 999 due to the rear sway bar. Plus I believe 1970 was the last year for drum brakes, this car has discs. It is still a legit RK41N car though, which is awesome. Would like to see what agency used this car. There was a legit LAPD Belvedere for sale at The Nats. I used to own a 1970 Plymouth Satellite that was a Seattle PD traffic car, it was a cool car to drive. The Seattle Police Museum has since bought it and restored it back to in service condition. Here is a link to the info on the car, I took the pic in 1999. http://www.seametropolicemuseum.org/docs/Seattle_Police_Car.pdf
[Re: hergfest]
#1282726
08/12/12 12:32 AM
08/12/12 12:32 AM
autoxcuda
So Cal
Interesting.
Do the SO numbers on the data tag correspond to any particular agency or special fleet custom buyer. I thought some of the LAPD and CHP cars were built to each agencies custom spec.
Also, could you decode that tag I posted? I don't know what the F codes stand for. I took that tag from a Satelite in the Wilmington, CA Pick A Part "big yard" in about 1989 or so.
[Re: 6bblgt]
#1282728
08/12/12 02:19 AM
08/12/12 02:19 AM
Posts: 17,552 Las Vegas, NV
6bblgt
Las Vegas, NV
the 1969 "US BORDER PATROL" Plymouth Belvedere POLICE 2-seat station wagon does this look correct? 11126 173399 9A162633 + 900 595 091 **** 26
99 99 L2T T7 RK45 E63 D32 B04 970004900 = 383 4bbl (330hp) turquoise engine without A/C (STD production # for b-bodies) 595 = 3.23 s/g 11" drums big u-joint (STD production # for b-bodies) 091 = 727 for (non-HP) 383 4bbl #2892091 (STD production # for b-bodies) 99 = "special order paint" color of the tag looks like FLEET color EF4 "light green" The transmission number is the same as '69 383 a-bodies GOT PICS??
[Re: 6bblgt]
#1282730
08/12/12 03:04 AM
08/12/12 03:04 AM
autoxcuda
So Cal
F58 - RR C/M reinforcement / welds (rear crossmember??) F72 - single key package F13 - HD alternator 60 AMP F38 - roof reinforcement
Thanks.
I'll try a decode. Please correct if I'm wrong...
N97 - Noise reduction package Y39 - Special order F58 - RR C/M reinforcement / welds (rear crossmember??) F72 - single key package H51 - A/C J52 - Inside hood release M25 - Wide sill moldings ??odd?? M?? - GY8 Roof Paint Code: Gold Metallic U - U.S. Specs B42 - HD disk drakes ??with 11" rear drums?? B51 - Power brake F13 - HD alternator 60 AMP F38 - roof reinforcement GY8 Paint Code: Gold Metallic L - Low 2 - Vinyl Bench T3 - Light Tan GT8 - upper door frame 428 Date Built: 4 / 28 / 1971 SO#: J132N1 ??N?? must be reading wrong E65 - 383-4 Barrel Roadrunner / Superbee D32 - H-D 727 TorqueFlite Trans RK - Plymouth Belvedere/Satellite, Police 41 - 4 Door Sedan N - 383 300HP 1-4BBL 8 CYL 1 - 1971 G - St. Louis, MO, USA
[Re: 6bblgt]
#1282735
08/12/12 04:00 AM
08/12/12 04:00 AM
autoxcuda
So Cal
N97 - Noise reduction package Y39 - Special order F58 - RR C/M reinforcement / welds (rear crossmember??) F72 - single key package H51 - A/C J52 - Inside hood release M25 - sill moldings ??odd?? N41 - dual exhaust GY8 Roof Paint Code: Gold Leaf Metallic U - U.S. Specs B42 - HD disk drakes ??with 11" rear drums?? B51 - Power brake F13 - HD alternator 60 AMP F38 - roof reinforcement GY8 Paint Code: Gold Leaf Metallic L - Low 2 - Vinyl Bench T3 - Light Tan GT8 - upper door frame Paint Code: Tahitian Walnut Metallic 428 SCheduled Production Date: Wednesday 4 / 28 / 1971 VON: vehicle order number J132N1 ??N?? must be reading wrong E65 - 383-4 Barrel (only 1 4bbl engine was available in B & E-bodies in '71) D32 - 727 TorqueFlite Trans RK - Plymouth Belvedere Police 41 - 4 Door Sedan N - 383 300HP 1-4BBL 8 CYL 1 - 1971 G - St. Louis, MO, USA
Thanks, N41 makes more sense.
Also, did the B42 HD disk come with 11" rear brakes like the T/A-AAR's had?
I can picture the gold Satelite police car in my head. But I can't remember if I got any parts off it. I was looking for 71 383 HP motor to replace the .040 motor in my Challenger R/T.
Got a 71 383 HP short block about that same time out of a 71 Polara "K" code car with like 70K original miles. Shame the car was in the yard, it was a very nice car. I should have just honed the block, but machine shop "convinced" us to rebuilt it. I say "K" code because the car was all white, had cloth insert seats, no light bar holes, Goodyear high miler hoses. The guy who spotted the car thought it was a Fire Chief's car or someone of that nature. It didn't seem to have been used for real Police duty. That guy got the fender tag.
[Re: Alaskan_TA]
#1282737
08/12/12 04:09 AM
08/12/12 04:09 AM
autoxcuda
So Cal
Can you get a clear photo of the whole tag?
Yes.
But it's at my parent's house. Maybe later this week.
[Re: stateline]
#1282739
08/12/12 10:06 PM
08/12/12 10:06 PM
wate
saw the topic and thought I'd add a bit. I own a 70 Plymouth Belvedere 4 dr ex colorado pursuit car. RK41NOA. 383 4 barrel car, has the factory front disc brakes, large rear drums, front sway bar, doesn't look like it ever had a rear sway bar, hemi torsion bars, 80 lb oil pressure dash gauge, white exterior, brown interior, radio delete, non air, nice original rubber mat floor covers, spotlights, SPD 7/4/70. Bought as a project, was sitting around for several years. Has a fender tag, don't have in front of me right now.
