"69 Roadrunner/Tires??? #1282672
08/10/12 12:06 AM
08/10/12 12:06 AM
Newfoundland Canada
Mopar1 Offline OP
Mopar1  Offline OP
Newfoundland Canada
My bro just bought a '69 Roadrunner and he wants to change out the wheels and tires. He wants to use 255/60/15's on the rear and 215/70/15's on the front. Will there be any issues with the 215's rubbing the front fenders? The tires are BFG T/A's and are mounted on 15X7 Keystone Klassics.
Re: "69 Roadrunner/Tires??? [Re: Mopar1] #1282673
08/10/12 12:27 AM
08/10/12 12:27 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
I have a 69' Roadrunner with 15" steel wheels and BFG 215/70/15 tires. There are no problems with clearance.
Re: "69 Roadrunner/Tires??? [Re: pacifica] #1282674
08/10/12 12:43 AM
08/10/12 12:43 AM
Newfoundland Canada
Mopar1 Offline OP
Mopar1  Offline OP
Newfoundland Canada
Thanks Pacifica. Nice lookin' ride there too!!
Re: "69 Roadrunner/Tires??? [Re: Mopar1] #1282675
08/10/12 07:15 AM
08/10/12 07:15 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
225/70's will work fine in front, maybe rub in an extreme turn situation. Candidly, the 215's will look a little small given you going larger on the back (IMO).
In back 275/60 is pretty much the "default" size that will nicely fill the wheel well.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: "69 Roadrunner/Tires??? [Re: Kowal] #1282676
08/10/12 08:33 PM
08/10/12 08:33 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I'm using 225/60-15's on 15x7 wheels up front and 255/60-15's on 15x8.5 on the rear with no problems. Could even go with 275/60-15's on the same 15x8.5 wheels on the rear if he wanted to.
215/70-15 should be no problem.
Re: "69 Roadrunner/Tires??? [Re: A12] #1282677
08/10/12 10:34 PM
08/10/12 10:34 PM
Newfoundland Canada
Mopar1 Offline OP
Mopar1  Offline OP
Newfoundland Canada
Thanks guys, he going with 255/60's on the back and 215/70's in front.
