Page 10 of 32 1 2 8 9 10 11 12 31 32
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282410
03/11/14 09:38 PM
03/11/14 09:38 PM
new jersey
Black 69 Beeper Offline OP
new jersey
sorry had to mess with something new. kids.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282411
03/14/14 09:15 PM
03/14/14 09:15 PM
new jersey
new jersey
driver side floor is a fit and screwed in with 1/4 inch holes drilled for plug welds.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282412
03/15/14 06:02 PM
03/15/14 06:02 PM
new jersey
new jersey
driver floor all welded top and bottom. next 4 speed hump will be put back in as well as the e brake bracket and speed o cable bracket.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282413
03/17/14 07:03 PM
03/17/14 07:03 PM
new jersey
new jersey
driver floor is done. all welds are ground down. i have to reinstall the 4 speed hump and install the sill covers, speed o cable bracket, and e brake cable bracket.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282414
03/17/14 07:04 PM
03/17/14 07:04 PM
new jersey
new jersey
shot of the floors from the passenger side.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282415
03/17/14 07:05 PM
03/17/14 07:05 PM
new jersey
new jersey
last of the major fabrication work. this is on the driver side under the back seat.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282416
03/17/14 07:06 PM
03/17/14 07:06 PM
new jersey
new jersey
heres one of the 2 pieces to be fabricated.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282417
03/17/14 07:06 PM
03/17/14 07:06 PM
new jersey
new jersey
all cut out.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282418
03/18/14 11:29 PM
03/18/14 11:29 PM
new jersey
new jersey
drivers side under back seat. one side fit the other side cut out.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282419
03/18/14 11:31 PM
03/18/14 11:31 PM
new jersey
new jersey
being that i don't have the means to make this piece as one and i don't need the whole floor under the back seat. i am making what i need in 2 pieces. everything under the patch will be treated and weld thru primer will be applied.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282420
03/18/14 11:33 PM
03/18/14 11:33 PM
new jersey
new jersey
second piece will be cut , trimmed, and fit. then welded and the bottom back seat seat hook will be reinstalled.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282421
03/19/14 10:26 PM
03/19/14 10:26 PM
new jersey
new jersey
4 speed hump welded back in. copper weld thru primer was used.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282422
03/19/14 10:27 PM
03/19/14 10:27 PM
new jersey
new jersey
floors all finished.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282423
03/19/14 10:27 PM
03/19/14 10:27 PM
new jersey
new jersey
another of the finished floors.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282424
03/19/14 10:29 PM
03/19/14 10:29 PM
new jersey
new jersey
drivers side under the back seat. pieces are fabricated and fit. copper weld thru was used the treat the top of the frame rails and the underside of the pieces that were made.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282425
03/19/14 10:30 PM
03/19/14 10:30 PM
new jersey
new jersey
under rear seat with the seat bottom brackets mocked up.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282426
03/19/14 10:33 PM
03/19/14 10:33 PM
new jersey
new jersey
all welded up. the last of the major fab work.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282427
03/20/14 07:11 PM
03/20/14 07:11 PM
new jersey
new jersey
reinstalled the wiring harness sill plate covers. had to weld new tabs on the back one.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282428
03/20/14 07:11 PM
03/20/14 07:11 PM
new jersey
new jersey
back one.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282429
03/24/14 10:20 PM
03/24/14 10:20 PM
new jersey
new jersey
all the floors are finished, scuffed, treated and ready to be epoxy primed with PPG DP90LF black primer sealer. then everything gets seam sealed.
