Page 7 of 32 1 2 5 6 7 8 9 31 32
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282350
01/29/14 11:11 PM
01/29/14 11:11 PM
new jersey
Black 69 Beeper Offline OP
new jersey
k frame epoxy primed with PPG DP90LF black primer.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282351
01/29/14 11:12 PM
01/29/14 11:12 PM
new jersey
new jersey
k frame painted satin black.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282352
01/29/14 11:13 PM
01/29/14 11:13 PM
new jersey
new jersey
passenger side front rocker and lower cowl area
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282353
01/29/14 11:14 PM
01/29/14 11:14 PM
new jersey
new jersey
all cut out
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282354
01/29/14 11:15 PM
01/29/14 11:15 PM
new jersey
new jersey
pieces fabricated and test fit
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282355
01/29/14 11:16 PM
01/29/14 11:16 PM
new jersey
new jersey
all welded up.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282356
01/29/14 11:17 PM
01/29/14 11:17 PM
new jersey
new jersey
driver frame rail and upper control arm bracket removal.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282357
01/29/14 11:18 PM
01/29/14 11:18 PM
new jersey
new jersey
old bracket, yucky!
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282358
01/29/14 11:21 PM
01/29/14 11:21 PM
new jersey
new jersey
new bracket blasted and ready to go back in. first i will install the upper control are with new bushings installed already. everything will be bolted up and pre-fit. once everything is good, it will be welded into place.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282359
01/31/14 05:48 PM
01/31/14 05:48 PM
new jersey
new jersey
lower control arms painted to look correct.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282360
01/31/14 05:48 PM
01/31/14 05:48 PM
new jersey
new jersey
painted and new parts installed.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282361
02/01/14 07:28 PM
02/01/14 07:28 PM
new jersey
new jersey
all done re welding the upper control arm bracket with a rust free original.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282362
02/01/14 07:29 PM
02/01/14 07:29 PM
new jersey
new jersey
patch on the inner drivers side frame rail.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282363
02/03/14 12:39 AM
02/03/14 12:39 AM
new jersey
new jersey
So i bought this wand that goes on a spray can to get into the inside of a frame rail. I went to do the passenger side rail and couldn't get the wand in the hole in the top of the rail. I knew right away based on the other side what was up. I cut a 1inch square hole in the side of the rail and this is what i pulled out.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282364
02/03/14 12:41 AM
02/03/14 12:41 AM
new jersey
new jersey
all treated inside with etch primer and welded up.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282365
02/03/14 12:42 AM
02/03/14 12:42 AM
new jersey
new jersey
ground down and good as new.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282366
02/03/14 12:43 AM
02/03/14 12:43 AM
new jersey
new jersey
scrapped all the undercoat off the inside front wheel wells.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282367
02/03/14 12:44 AM
02/03/14 12:44 AM
new jersey
new jersey
stripped both sides with a roloc disc.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282368
02/03/14 11:33 PM
02/03/14 11:33 PM
new jersey
new jersey
driver side door post area
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282369
02/03/14 11:33 PM
02/03/14 11:33 PM
new jersey
new jersey
driver side door post. all better
