Crane 66970-1 dissy gear for roller cams..input needed #1281709
08/08/12 08:36 PM
08/08/12 08:36 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Anyone have some real world experiance with this? I have a new 451 with a hyd roller cam that I'm almost ready to fire. It has a new Milodon bronze gear in it now. Should I get a Crane set up? I'm not into being a guinea pig... I can't afford to do this twice?
Comments?
Thanks Brad
Re: Crane 66970-1 dissy gear for roller cams..input needed [Re: brads70] #1281710
08/09/12 08:38 AM
08/09/12 08:38 AM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Hummmm no answers.... that's not a good sign! LOL
Re: Crane 66970-1 dissy gear for roller cams..input needed [Re: brads70] #1281711
08/09/12 09:07 AM
08/09/12 09:07 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I bought the Crane gear. It comes without the shaft. I couldn't find a source to purchase a shaft. I removed a gear from a shaft I had. But there's no easy way the salvage the pin. The pin is not a standard roll pin. It appears the fit between the gear and the shaft is an "interference" fit.
To make a long story short putting the gear on the shaft appears to be a job for a machine shop.
By the way, the instructions say not to use the gear on a cam that has already been used with another type of gear.
Re: Crane 66970-1 dissy gear for roller cams..input needed [Re: TooMany62s] #1281712
08/09/12 10:41 AM
08/09/12 10:41 AM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Thanks for the reply! Ya I read that about not using it on a used cam. Bummer about not supplying it with the shaft. Not very good marketing IMO?
Re: Crane 66970-1 dissy gear for roller cams..input needed [Re: brads70] #1281713
08/09/12 02:11 PM
08/09/12 02:11 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I believe either Milodon or Moroso used to sell Mopar oil pump shafts minus the gear. I can't find them in either of their catalogs anymore.
