High crankcase pressure?
#1281444
08/08/12 01:45 PM
08/08/12 01:45 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I have noticed that I am blowing oil out of the dipstick tube, and pushing the dipstick out. Is this an issue of high crankcase pressure or oil level too high?
The car sat a few years, and I just started driving it alot lately. now that I think back, I used to run the oil a little "low" and picked up a few tenths with no adverse effects.
360 stock pan/pickup hi volume oil pump PCV (new valve) breather in other valve cover
No signs of excessive blowby out of the breather. Engine has ~7k miles, <100 passes. I am worried that sitting may have messed with how the rings are sealing...but it doesn't smoke at all, even at the track. So should I just stop worrying and drain a 1/2 qt out of it??
Thanks! Dave
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
Re: High crankcase pressure?
[Re: OUTLAWD]
#1281446
08/08/12 01:54 PM
08/08/12 01:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Easiest thing to do is drain a little oil out then try it again.... but my opinion is the pressure getting past the rings... but see if they set in... you dont want to do what I'm doing now unless its needed
[Re: Cab_Burge]
#1281449
08/08/12 08:55 PM
08/08/12 08:55 PM
OUTLAWD
Metro Detroit
Thanks! Can't hurt to try... I had one of the on the pass side with a baffled gromet and a PCV on drivers side. Just replaced the fill cap with one of these I had laying around
[Re: bentwheel43]
#1281452
08/08/12 11:50 PM
08/08/12 11:50 PM
MR_P_BODY
this is the other side and I put the stock valley pan back on.
Why run a breather on it with a vac pump.... just put a adjustable relief valve set at a point IF that pump can pull enough vac
[Re: MR_P_BODY]
#1281453
08/09/12 12:20 AM
08/09/12 12:20 AM
Posts: 635 mississippi
bentwheel43
mississippi
when I pull the breather off and put my hand over it it sucks good and speeds the pump up when the cap is off.It got the pressure out of the motor.It also pull the water out as well as some oil maybe 3 oz in 8 or 9 passes.Stopped all the leaks it problilly would suck harder and maybe hurt the pump maybe becauce it will slow it down alot if I put a cap on it..I thank it cost about $125 for every thing.
Section 8 Racing We are nuts about racing.
[Re: MR_P_BODY]
#1281455
08/09/12 01:23 AM
08/09/12 01:23 AM
bentwheel43
mississippi
2000 firebird,it works real good keeping the water out of the valve cover.On a friend sb chevy it pulls 5# @ the stick tube.I don't know if he has a breather on it.
[Re: MoparPitBull]
#1281457
08/09/12 11:48 AM
08/09/12 11:48 AM
MR_P_BODY
Yes Mr.Body...GM smog air pump used on '99 Corvette.Used them on a few alky motor cars to remove condensation from oil...a poor mans vacuum pump so to speak.Must be mounted in correct position to work best.Advance Auto part #32-2600M @ $95 w/warranty.
Any idea what the amp draw is on them... what size fuse they run
[Re: MoparPitBull]
#1281459
08/09/12 06:29 PM
08/09/12 06:29 PM
OUTLAWD
Metro Detroit
hmm...I may try that pump out regardless of my problem, always wanted to try out a vac pump.
Mr.P, what kind of vacuum should I look for if I am setting a relief valve? Too much is a bad thing in this case, correct?
[Re: OUTLAWD]
#1281461
08/09/12 08:34 PM
08/09/12 08:34 PM
MR_P_BODY
It would depend on the pump.... on my dry sump I can get 12"HG with just the pump so I dont run a vac pump on it... if I were to use that I might set it at 5" to 6"HG... because I would think (from what the others are saying it might not like more) but I would have to see what the pump can do
[Re: OUTLAWD]
#1281462
08/09/12 08:53 PM
08/09/12 08:53 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
From listening to the radio chatter from the Denver NHRA race, someones crew member reported " data logger on, vacuum pump on" So I assume they are also useing an electric vacuum pump. Not like the one mentioned here, I'm sure, but be looking into one for my car too.
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
[Re: Dave_S]
#1281463
08/10/12 12:50 PM
08/10/12 12:50 PM
OUTLAWD
Metro Detroit
Doing some msg board searching, it appears as if a similar ford part off a 90's Cobra might be better. Didn't find it available anywhere though... F6ZZ-9A486-DA
One guy seemed to be blowing 20A fuses, Buit I'm not sure on his setup. There is some internal foam on the GM units that may restrict it, and it is suggested to remove it.
