74 RV-2 Compressor, Discharge Flange O-Ring #1281389
08/08/12 11:20 AM
08/08/12 11:20 AM
Creedmoor, NC, USA
74Charger Offline OP
Creedmoor, NC, USA
On the discharge hose off of the compressor, the flange that connects hose to compressor has an o-ring in a recessed groove. Where can I find that replacement o-ring? I had a leak there and need to repair.
I'm also using 134-A. Do I need to be concerned about o-ring material?
Re: 74 RV-2 Compressor, Discharge Flange O-Ring [Re: 74Charger] #1281390
08/08/12 11:45 AM
08/08/12 11:45 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Take the o ring to a place that works on A/C systems. I think material is important , the orings that came with the compressor for my Ram were green.
Re: 74 RV-2 Compressor, Discharge Flange O-Ring [Re: JohnRR] #1281391
08/08/12 06:24 PM
08/08/12 06:24 PM
Creedmoor, NC, USA
Creedmoor, NC, USA
Success at NAPA! Their part # for the o-ring needed is 407171. The gasket part # is 207182 for non o-ring applications or flanges, or at least I think so.
Remember to ask for an older guy when looking for this stuff!
