Alignment specs? #1280363
08/06/12 12:34 PM
08/06/12 12:34 PM
Downtown Roebuck Ont
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Does anybody have a set of all around good street specs for improved handling over factory specs? I have a 79 R-body, a 65 C-body wagon and a 66 C-body sedan.
The guy who's skills I trust works at a shop that just got a new whizz bang alignment system and the computer in it doesn't recognize dinosaurs
My understanding has always been to jack in as much positive castor as it will give you and hope when you're done with the camber and toe that you have some left.
Kevin
Re: Alignment specs? [Re: Twostick] #1280364
08/06/12 12:43 PM
08/06/12 12:43 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
web page
The tech archives are your friend.
You can even shoot for these setting at 1" above ride height to further improve high speed stability.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Alignment specs? [Re: bigsbigelow] #1280365
08/06/12 01:24 PM
08/06/12 01:24 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
web page
Are those specs for racing in a straight line.. or are they also good for cornering?
Re: Alignment specs? [Re: Jeepmon] #1280366
08/06/12 01:53 PM
08/06/12 01:53 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Check out this article. Specs are in the chart about 3/4 of the way down the page.
http://www.allpar.com/history/mopar/front-end-alignment.html
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: Alignment specs? [Re: bigsbigelow] #1280367
08/06/12 02:20 PM
08/06/12 02:20 PM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Where is the head banging smiley when you need it?
Those specs are suitable for all platforms? Also can I assume that for max tire life I would go for 0 camber instead of -.5?
At 1" above ride, where approx would they be at ride height?
Kevin
Re: Alignment specs? [Re: Twostick] #1280368
08/06/12 02:57 PM
08/06/12 02:57 PM
bigsbigelow Offline
bigsbigelow  Offline
The specs in the tech archive state that they are a good setting for our cars that use radial tires. I figure they are pretty similar to a late model daily driver alignment spec I don't know what happens to the specs when the car is dropped back down from the 1" up position. My car was set up with these specs and I really like the way it drives.
Re: Alignment specs? [Re: lilcuda] #1280369
08/06/12 03:10 PM
08/06/12 03:10 PM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Thanx. Good article.
As usual C-bodies get no respect but at least he included R-bodies. I was concerned about a negative camber # causing tire wear but some factory specs call for slight positive so I'm likely thinking too much again.
Kevin
Re: Alignment specs? [Re: Twostick] #1280370
08/06/12 03:20 PM
08/06/12 03:20 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Radials are less sensitive to camber in regards to tire wear than bias ply tires. Too much toe either in or out will definitely cause rapid wear. Strut rod bushings are crucial to maintaining toe. 1/2 a degree neg. camber won't cause any tire wear issues.
Re: Alignment specs? [Re: 5spdcuda] #1280371
08/06/12 04:40 PM
08/06/12 04:40 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
If tire wear is your main concern then aligh accordingly. If you want it to handle put in some neg camber. I've been running .7- for about 1k miles and I've finally wore the whiskers off my front tires.
Mopar to the bone!!!
Re: Alignment specs? [Re: Twostick] #1280372
08/06/12 10:55 PM
08/06/12 10:55 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You should spend a 170 bucks and buy a gauge and do it yourself. I have experimented with settings and to make sure they stay put and don't change.
I have found a little neg camber1/4 degree and 4 degrees of positve caster makes for killer handling car.
I used Firm Feel upper control arms and it transformed my car.
Re: Alignment specs? [Re: 72Swinger] #1280373
08/06/12 11:40 PM
08/06/12 11:40 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I agree, same here! .7 of a degree and next to zero tire wear.
Re: Alignment specs? [Re: Jeepmon] #1280374
08/07/12 12:46 AM
08/07/12 12:46 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
web page
The chassis manual recommends drag cars use the stock settings, with possibly a bit more positive caster for high speed stability. However, those settings should be done at one inch of lift in the front end to simulate body rise through the traps with the light weight drag style front suspension.
The othe rpsecs recommended on here are good all around driving specs for use on a street car with radials.
Going fast around corner specs actually will have more negative camber and less toe in.
Re: Alignment specs? [Re: brads70] #1280375
08/07/12 01:34 AM
08/07/12 01:34 AM
IN
ahy Offline
ahy  Offline
IN
Agree... some negative camber .5-.75 deg - won't hurt tire wear much with radials and helps handling. If you drive it in corners the negative camber might actually help even out tire wear.
As much positive caster as possible up to 5 degrees or so.
I like to run on the high side of factory spec for toe in to promote stability, especially with wider tires. For autocross, less toe is recommended for improved responsivness. I'll take the stability.
If your setup can't get that much, at least a little of both (negative camber and positive caster) will help.
I know on my setup, getting alignment dialed in with the help of FF UCA's and adjustable strut rods made a huge difference in how it handled.
Re: Alignment specs? [Re: ahy] #1280376
08/07/12 10:39 AM
08/07/12 10:39 AM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Sounds like -.50 is a safe number to try for handling vs tire wear. I was just concerned it was going to cut my tire life in half. They don't drive bad enough to make that sacrifice . My local guy's new machine doesn't recognize dinosaurs so I don't even know what the stock settings are.
Kevin
Re: Alignment specs? [Re: Twostick] #1280377
08/07/12 12:04 PM
08/07/12 12:04 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
For a confidently handling street car we suggest:
6-8* of caster
1-1.5* of negative camber
roughly 1/16 total toe in
for our "race" cars:
8-10* caster
1.5-2.5* of negative camber
toe to max G's or track application
Re: Alignment specs? [Re: Dan@Hotchkis] #1280378
08/07/12 12:17 PM
08/07/12 12:17 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Dan, why so much caster? Normally, I like the 3-4 range.
Re: Alignment specs? [Re: BergmanAutoCraft] #1280379
08/07/12 05:15 PM
08/07/12 05:15 PM
Improved camber curve on turns. Look at any modern performance car today and you will see the same. I believe the Corvettes have 8* from the factory.
Re: Alignment specs? [Re: Dan@Hotchkis] #1280380
08/07/12 05:48 PM
08/07/12 05:48 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Heck, look at BMWs and Mercedes when their wheels are cranked to one side. They have so much caster you'd think something's broken!
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
