Re: Head + Intake Flow bench #s / flow loss with intake
[Re: BradH]
#1280351
08/06/12 12:29 PM
08/06/12 12:29 PM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
FWIW, more misc. tech stuff...
I've done some flow testing of my CNC Victors w/ my "Franken-intake" modified MP M1 RB and wanted to compare them to what I saw doing the same type of tests w/ my old Stage VIs w/ an earlier version of the same intake manifold.
Stage VIs + M1 Intake v1 Lift -- #1 -- #3 -- #6 -- #8 .600" - 288 - 282 - 280 - 288 (Avg 285) .650" - 292 - 284 - 283 - 292 (Avg 289)
Victors + M1 Intake v2 Lift -- #1 -- #3 -- #6 -- #8 .600" - 312 - 312 - 308 - 312 (Avg 311) .650" - 317 - 317 - 313 - 320 (Avg 317)
Keep in mind the Stage VIs were used w/ a .600" (gross) lift solid flat-tappet cam, but the Victors are going to be using a .650" (gross) solid roller.
The head-only flow #s for the Stage VIs maxed about 310, whereas the Victors are closer to 350. I noticed the additional work I did to the intake is still lagging behind the flow increase w/ the new heads, since the average flow loss w/ the intake on the Stage VIs was ~ 6% vs. an average loss on the Victors of ~ 9%.
Anyone have other examples of flow loss % when intakes are installed vs. the heads by themselves?
Andy did some manifold testing using a set of 350cfm Indy EZ's and various manifolds bolted up.
http://www.moparmusclemagazine.com/techarticles/mopp_0701_mopar_intake_manifold/edelbrock.html
Your std port modded M1 looks pretty good in comparison to the results posted in the link above
Ron
[Re: BradH]
#1280352
08/06/12 12:34 PM
08/06/12 12:34 PM
Posts: 5,620 long island NY
Ari440
long island NY
any pics ?
1.39 9.85 - 137 mph
[Re: BradH]
#1280354
08/06/12 03:03 PM
08/06/12 03:03 PM
Posts: 31,203 Oregon
AndyF
I redid my website so you don't have to go far to dig up stuff anymore. www.arengineering.com then click on tech articles. The intake flow bench work is on there. One thing I've observed is that an intake with bad flow numbers will not make power. But an intake with good flow numbers will not necessarily make lots of power.
[Re: BradH]
#1280357
08/07/12 12:57 PM
08/07/12 12:57 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I have a Victor 440 (4150), but haven't taken the time to do any work on it to match the heads. It's also so tall that it doesn't leave any room under the scoop for any spacers.
The 337 seems more suited to bigger engines + MW-sized heads.
the 337 port is on the small size where it meets the head. and I thought you have slightly over sized ports on the heads you have. may be worth a look. If you compare the plenum and port entry of the 337 to the victor, the 337 IMO looks better although, like you said it might be more suited for more cubes but your motor is no slouch for a small block
can you tell I really like the 337 intake? I tried a victor intake on my 493 when I was running standard ports with a couple different carbs and was not happy with the results. only slightly faster than stock six pack intake and way slower than weiand cross ram and weiand tunnel ram six pack.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1280358
08/07/12 01:13 PM
08/07/12 01:13 PM
Ari440
long island NY
which one was faster
1.39 9.85 - 137 mph
