2001 durango ac is warm then cold #1280308
08/06/12 09:54 AM
08/06/12 09:54 AM
Carson City, NV
babarracuda Offline OP
Carson City, NV
When wwaitinf at the drive thru, the ac stareted blowing warm. Turned it off and after I started moving, it was cold when I turned it on. Any sugggestions?
Re: 2001 durango ac is warm then cold [Re: babarracuda] #1280309
08/06/12 10:44 AM
08/06/12 10:44 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Get the pressures checked that will get you in the right direction. Could be alot of things at this point.
Re: 2001 durango ac is warm then cold [Re: Todd] #1280310
08/06/12 01:25 PM
08/06/12 01:25 PM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Mine did that too and now I have no a/c and it will not hold a charge..
Re: 2001 durango ac is warm then cold [Re: bee71mopar] #1280311
08/06/12 02:02 PM
08/06/12 02:02 PM
NC
DCM71cuda Offline
DCM71cuda  Offline
NC
If you have a/c (cold) when you are moving, but it blows hot when you are stopped or driving slowly, I would check the condenser fan motor.
Re: 2001 durango ac is warm then cold [Re: DCM71cuda] #1280312
08/06/12 05:36 PM
08/06/12 05:36 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Yupper fan motor I agree:
Re: 2001 durango ac is warm then cold [Re: dynamite] #1280313
08/06/12 07:27 PM
08/06/12 07:27 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Also check the condenser fan relay in the fuse box. They are prone to burn up. In some cases they will also take out the condenser relay circuit in the PCM.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
