drive line slip yoke
#1280272
08/06/12 03:40 AM
08/06/12 03:40 AM
Posts: 256 libby mt
lifted85
libby mt
OK i found a drive line, i think it came out of a 904, the tranny looks like a 904 as it has the hump on the left side, but any way's is it true that a 904 slip yoke wont fit in a 833 OD?? i am asking because i finally found 1 after looking for a few weeks for the 2wd project, they guy has no info on the parts ect ect an he lives 2 hours away, would really hate to jump in the ol gas hog lol an drive over for nothing ya know...
drive fast, drive hard, DRIVE MOPAR
Re: drive line slip yoke
[Re: scratchnfotraction]
#1280276
08/07/12 02:50 AM
08/07/12 02:50 AM
Posts: 256 libby mt
lifted85
libby mt
OK, can i get away with, taking a 727 slip yoke an putting it on the np435 drive shaft that is already under my 2wd??? or will the drive shaft to to short or to long?? if its to long i can always have it cut no biggie... i was told i should be able to just find a 727/a833 slip yoke an do it that way but just want to make sure before i go all hands in lol ![](/ubbthreads/images/graemlins/smile.gif) ... got like 9 days to build the truck hahaha so just trying to get every thing lined up...
#1280278
08/07/12 06:23 PM
08/07/12 06:23 PM
Posts: 256 libby mt
lifted85
libby mt
see on my last thread a guy said i should beable to use the drive line that was already in my 2wd, i would just need a conversion u joint?? i am loading the tranny up to day an taking it with me to the J/y to see if i can find the right slip yoke that fits it, the owner said he might have one off some old 727's.. i never really looked at the drive line that was under the 2wd lol, the truck is out at a budy's, like i said if the drive line is to long i can always get it cut no biggie, the problem is if its to short lol...
[Re: lifted85]
#1280279
08/07/12 11:03 PM
08/07/12 11:03 PM
Posts: 15,487 Florida
scratchnfotraction
OK, can i get away with, taking a 727 slip yoke an putting it on the np435 drive shaft that is already under my 2wd??? or will the drive shaft to to short or to long?? if its to long i can always have it cut no biggie... i was told i should be able to just find a 727/a833 slip yoke an do it that way but just want to make sure before i go all hands in lol ... got like 9 days to build the truck hahaha so just trying to get every thing lined up...
a NP435 should have a bolt on yoke on the output shaft of the trans,this needs a drive shaft with a spline shaft and a slip yoke that fits the slip splines.
a 904 or 727/833 use a drive shaft with a yoke that slide in the tail shaft of a trans.
you can not put the 727.833 yoke on a np 435 drive shaft..
if you have a 904/727/833 you need the correct size slip yoke with a drive saft that is built for that type of yoke.
slide your yoke all the way into the tail shaft till it bottoms out,measure from cup to cup and sbtract 1" for correct length shaft.
unless I am missing something. ![](/ubbthreads/images/graemlins/shruggy.gif)
what trans do you want to run in the 2x truck?
