Page 3 of 5 1 2 3 4 5
Re: My little truck small block...*more updates* [Re: racerx] #1280021
09/28/12 08:40 PM
09/28/12 08:40 PM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
Thanks, not sure I have the front low enough yet but it's going to stay like it is for now......................................................Me personally i would like to see it a little lower in the front but it your truck long as u r HAPPY...
Yeah, the more I look at it, the more I think it still needs to come down a little...oh well, now that they're cut they will be easier to get out the second time
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: My little truck small block...*more updates* [Re: RapidusMaximus] #1280022
09/29/12 02:19 AM
09/29/12 02:19 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Looks SWEET! Keep the pics coming.
Re: My little truck small block...*more updates* [Re: 77ProStreet] #1280023
10/03/12 10:05 AM
10/03/12 10:05 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Any new news on this build?I'm really thinking of doing a short body/boosted/sb/bb What year is your truck?is it the 78 in your sig?I,v already have a set of the cop wheels/pancake caps that i wanted to put on another project.I'll be keeping an eye on this thread............
Re: My little truck small block...*more updates* [Re: racerx] #1280024
10/03/12 10:23 PM
10/03/12 10:23 PM
Weatherford, Texas
Weatherford, Texas
yeah its a 78, finished lowering the front 2 inches (pics coming) and now I'm fighting the tune...
1968 Plymouth GTX
Re: My little truck small block...*more updates* [Re: RapidusMaximus] #1280025
10/03/12 10:28 PM
10/03/12 10:28 PM
Weatherford, Texas
Weatherford, Texas
Appears I still have the valves adjusted too tight... or the cam timing is off...can't seem to get it to stop "detonating" at part throttle and trying to "butterfly" back through the carb...ugh...
1968 Plymouth GTX
Re: My little truck small block...*more updates* [Re: RapidusMaximus] #1280026
10/04/12 08:53 AM
10/04/12 08:53 AM
scratchnfotraction Offline
how much off the coil spring now?
Re: My little truck small block...*more updates* [Re: scratchnfotraction] #1280027
10/04/12 09:34 AM
10/04/12 09:34 AM
Weatherford, Texas
Weatherford, Texas
Took a full coil off with the first cut then when that wasn't low enough I cut it twice more about 2" per cut...so...in the end it came out to be about a coil and a half which dropped it down to barely touching the bump stops, trimmed those about an inch so it would have some travel before contact. Drove it around the neighbor hood but haven't had it on the highway yet...still no windshield...ugh...
1968 Plymouth GTX
Re: My little truck small block...*more updates* [Re: RapidusMaximus] #1280028
10/04/12 10:01 AM
10/04/12 10:01 AM
New York
jagrunt551 Offline
jagrunt551  Offline
New York
Nice little truck!!! Now we need some new photos!!!
Re: My little truck small block...*more updates* [Re: jagrunt551] #1280029
10/04/12 09:04 PM
10/04/12 09:04 PM
Weatherford, Texas
Weatherford, Texas
Truck is undergoing intense color sanding and buffing pics will follow shortly thereafter...
1968 Plymouth GTX
Re: My little truck small block...*more updates* [Re: RapidusMaximus] #1280030
10/14/12 09:54 AM
10/14/12 09:54 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Don't what cha' to get to far down on the forum so i'll give u a any new updates?
Re: My little truck small block...*more updates* [Re: racerx] #1280031
10/14/12 11:33 AM
10/14/12 11:33 AM
Weatherford, Texas
Weatherford, Texas
Yeah, worked on it all day yesterday fine tuning my timing issue...turns out that for some reason the balancer had 2 timing marks and I had the timing so far advanced(accidentally) that I could see the "wrong" timing mark with the timing light. The "wrong" timing mark was telling me that I was at 10 degrees behind when I was actually about 20 degrees advanced anyway, got it figured out and also tuned the stumble out of it. Now for the frustrating part, after the painter sanded the entire passenger side with 1000 grit he decided he had little league baseball he needed to be doing, haven't seen him since , he hasn't even started on the drivers side and he has lots of orange peel to get out. The front and back glass are still not in, the installer says the front window is on back order...sheesh...
1968 Plymouth GTX
Re: My little truck small block...*more updates* [Re: RapidusMaximus] #1280032
10/14/12 12:26 PM
10/14/12 12:26 PM
Weatherford, Texas
Weatherford, Texas
However...I did leave a small set of marks in the driveway and drove it down the highway with no windshield, no inspection, no tags...no front and back window was a bit "airish"... but it did run out pretty nice Pics coming...
1968 Plymouth GTX
Re: My little truck small block...*more updates* [Re: RapidusMaximus] #1280033
10/14/12 07:47 PM
10/14/12 07:47 PM
Weatherford, Texas
Weatherford, Texas
So, today while the painter was color sanding I decided to do something that was talked about in an earlier thread...put a front bumper on the back... . Worked the bow out of it, took the bumper mounts off of the step bumper and did a little cutting, fitting and welding. It still needs a little shimming here and there and some bumper bolts. What do you think?
1968 Plymouth GTX
Re: My little truck small block...*more updates* [Re: RapidusMaximus] #1280034
10/14/12 08:57 PM
10/14/12 08:57 PM
Lehigh Acres, Florida
rickstershemi Offline
looks awesome....been waiting to see this done
Rickster
Re: My little truck small block...*more updates* [Re: RapidusMaximus] #1280035
10/14/12 09:29 PM
10/14/12 09:29 PM
Nunnelly, TN
Kevin I Offline
Kevin I  Offline
Nunnelly, TN
I think it looks good. Not as good as a real rear bumper, but 1000 times better than a step bumper.
Re: My little truck small block...*more updates* [Re: Kevin I] #1280036
10/14/12 11:23 PM
10/14/12 11:23 PM
Weatherford, Texas
Weatherford, Texas
Yeah, the step bumper was a no go...you wouldn't believe how we got the bow out of this front bumper... LOL. the step bumper mounts were cut off about 3 inches and provided just enough material for mounting the bumper. the trick was that the frame rails were a few inches wider than the bolt holes on the bumper...the excess mount material was used to adapt between the two, little welding, little fabrication and wala...
1968 Plymouth GTX
Re: My little truck small block...*more updates* [Re: RapidusMaximus] #1280037
10/15/12 09:03 AM
10/15/12 09:03 AM
lookin good. i like that rear bumper even if it is off the front.
Re: My little truck small block...*more updates* [Re: Kevin I] #1280038
10/15/12 01:38 PM
10/15/12 01:38 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
^^^This^^^or what do u think of roll pans?
Re: My little truck small block...*more updates* [Re: racerx] #1280039
10/15/12 09:54 PM
10/15/12 09:54 PM
Weatherford, Texas
Weatherford, Texas
Hmmmmm, roll pans...after shimming this bumper and installing the proper bumper bolts I'll see if I still like it...if not, I'll be shopping for roll pans.
1968 Plymouth GTX
Re: My little truck small block...*more updates* [Re: RapidusMaximus] #1280040
10/23/12 07:05 PM
10/23/12 07:05 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Any updates?
