Page 1 of 5 1 2 3 4 5
My little truck small block...*more updates* #1279981
08/05/12 09:06 PM
08/05/12 09:06 PM
Weatherford, Texas
RapidusMaximus Online content OP
RapidusMaximus  Online Content OP
Weatherford, Texas
Couldn't help myself...spent almost all day in the shop in the 100+ heat. Got the little 360 engine almost together, RHS Indy X heads by Brian @ IMM showed up Friday and the UPS man has been to visit me regularly the last couple of weeks and here are the results...thanks Brian
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: My little truck small block... [Re: RapidusMaximus] #1279982
08/05/12 09:19 PM
08/05/12 09:19 PM
scratchnfotraction Offline
looks sweet!
thanks for shareing pics of your project. I always like to see what other are working on.
Re: My little truck small block... [Re: scratchnfotraction] #1279983
08/05/12 09:24 PM
08/05/12 09:24 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
..but I wanna see more of that GTX.....
1981 Dodge D150 360 auto
Re: My little truck small block... [Re: basketcase] #1279984
08/05/12 09:30 PM
08/05/12 09:30 PM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
What Pistons/compression did you go with?
Re: My little truck small block... [Re: scratchnfotraction] #1279985
08/05/12 09:31 PM
08/05/12 09:31 PM
Weatherford, Texas
Weatherford, Texas
looks sweet!
Thanks, truck should be out of the paint shop this week, A body rear is built and ready to go...I'm gettin antsy...
1968 Plymouth GTX
Re: My little truck small block... [Re: basketcase] #1279986
08/05/12 09:33 PM
08/05/12 09:33 PM
Weatherford, Texas
Weatherford, Texas
Finished almost all of the metal work on the GTX then started playing with this truck...so it's on the back burner for a couple of months.
1968 Plymouth GTX
Re: My little truck small block... [Re: 72swgnr] #1279987
08/05/12 09:36 PM
08/05/12 09:36 PM
Weatherford, Texas
Weatherford, Texas
Went with .030 over flat top KB's, block is zero deck and with the RHS heads it should yield a C/R of somewhere around 10 to 1.
1968 Plymouth GTX
Re: My little truck small block... [Re: RapidusMaximus] #1279988
08/06/12 01:04 PM
08/06/12 01:04 PM
what gears in the 8 3/4?
i cant wait to see it with the A-body 8 3/4
Re: My little truck small block... [Re: scratchnfotraction] #1279989
08/06/12 02:42 PM
08/06/12 02:42 PM
Weatherford, Texas
Weatherford, Texas
The rear is a 489 case with a 3.55 sure grip, cleaned up, painted, new brakes, new drums, new hydraulics, chompin at the bit to get it in and start measuring for wheels and tires.
1968 Plymouth GTX
Re: My little truck small block... [Re: RapidusMaximus] #1279990
08/06/12 05:50 PM
08/06/12 05:50 PM
you have the large brake axles,correct?
12" wide with 4 1/2" backset 29x15x15 M/T SR radials fit in there just right.
dont forget the lip stick on the housing.
Re: My little truck small block... [Re: scratchnfotraction] #1279991
08/06/12 05:52 PM
08/06/12 05:52 PM
this is it bolted up. that should keep you chompin at the bit till you get it.
Re: My little truck small block... [Re: scratchnfotraction] #1279992
08/06/12 11:49 PM
08/06/12 11:49 PM
Weatherford, Texas
Weatherford, Texas
Exactly! , looks great, now if I can just get the dang truck out of the paint shop. , he sent me a pic of the cab Saturday... hopefully have it back in my shop by this weekend, pics will be posted.
1968 Plymouth GTX
Re: My little truck small block...*update* [Re: RapidusMaximus] #1279993
09/10/12 08:49 AM
09/10/12 08:49 AM
Weatherford, Texas
Weatherford, Texas
*Update* Got the engine in and almost ready to fire...drivers side valve cover is not on because it wont clear the power brake booster... , non-fabbed valve covers on the way...sheesh anybody want to buy some brand spanking new fabbed valve covers?????
And...wait for it...tires and wheels are in...just have to get them mounted and balanced...wheels are 15 X 12's from Stockton wheel tires are Micky Thompson S/R's...I'mm slowly getting there...travel during the week...work on the truck on weekend.
1968 Plymouth GTX
Re: My little truck small block...*update* [Re: RapidusMaximus] #1279994
09/10/12 09:04 AM
09/10/12 09:04 AM
Re: My little truck small block...*update* [Re: scratchnfotraction] #1279995
09/10/12 10:25 AM
09/10/12 10:25 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Do you have the small diameter booster. Id get 1 and use the fabed valve covers..
I am truckless..
Re: My little truck small block...*update* [Re: 340SHORTY] #1279996
09/10/12 01:50 PM
09/10/12 01:50 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
switch to the 3/4 ton booster, and keep the fabbed covers!
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: My little truck small block...*update* [Re: hp383] #1279997
09/10/12 03:41 PM
09/10/12 03:41 PM
x2
86 3/4 ton D-150 has the small booster with the alum 2 bolt MC or just go manual brakes.
Re: My little truck small block...*update* [Re: scratchnfotraction] #1279998
09/10/12 03:50 PM
09/10/12 03:50 PM
Weatherford, Texas
Weatherford, Texas
Well...I've already ordered the "tall" chrome valve covers from Mancini with the standard mount flanges...wasn't aware I could change the booster so I panicked and ordered the new stuff... oh well...if the new ones don't clear I'll be looking at changing the booster. The fabbed valve covers have the bolts integrated and that's the problem...you can't get a bolt in the back hole, the standard mount flange on the chrome covers should cure the problem. Hopefully...if not I'll be changing the booster...
1968 Plymouth GTX
Re: My little truck small block...*update* [Re: hp383] #1279999
09/10/12 04:09 PM
09/10/12 04:09 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Not 3/4 ton specific. Sami's 76 has the small booster
Re: My little truck small block...*more updates* [Re: 76dodgeboy] #1280000
09/13/12 08:30 PM
09/13/12 08:30 PM
Weatherford, Texas
Weatherford, Texas
Got the tires and wheels mounted, balanced and installed...
Rear view..
1968 Plymouth GTX
