Re: Holley or Carter? 1971 HP 383 with A/C [Re: 72roadrunnergtx] #1279417
08/17/12 01:06 AM
08/17/12 01:06 AM
IL
71383beep Offline
71383beep  Offline
IL
I will provide further first hand back-up of the existence of factory provided Carter conversion kits for the Holley 4160 applications, performed the conversion many times myself during my time at dealers back then. They were packaged as complete kits, fuel lines, choke springs, any other hardware required, fully covered if under warranty. Installed correctly, appeared completely factory installed. Can’t tell you just how many 4160’s wound up in the trash, considered pure junk then by those who serviced them and many under hood fires were blamed directly on them.
Yeah i read your posts on the bird nest which is why I am wondering if my 4966 AVS was a warranty replacement. I mean everything is where it should be, choke, hose routing, kick down, etc. The only thing it does not have is the ground wire to the dizzy, but the car was converted to the MP electronic ignition sometime in its life. I just was thinking if I could rebuild a 440 AVS for a bit more umpf and it would be a reasonable stock substitute.
i figured the original 4160 holley is next to impossible. Its not the end of the world I am more than happy to live with the carb(s) I have. I just wondered why I had an AVS.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 72roadrunnergtx] #1279418
08/19/12 09:56 PM
08/19/12 09:56 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
I bought my 71 Bee from the original owner back in 1984 - The motor had not been touched and the car still retained most of its original paint and interior - 100% #s matching - The car was also Ziebart undercoating straight from the dealer i was told from original owner as the Ziebart sticker still to this day resides in the rear window - I remember when i pulled the original motor there was Ziebart undercoating all over the valve covers / wiring / air cleaner / intake and fuel lines + Carter 6125S
Car was built in St Louis December 1970
Whos to say that Chrysler on late build cars didnt install the 6125s at the factory ??? Hell my 71 Bee has a 1972 Charger Heater Core in it from the factory
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Holley or Carter? 1971 HP 383 with A/C [Re: bee1971] #1279419
08/21/12 08:04 PM
08/21/12 08:04 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
The build sheet is the ultimate truth to what was supposed to be on there from the assembly line. Now whether or not the dealership switched things, IE interior, radio, spare tire, Carter AVS upgrade, only the dealership work orders know.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Holley or Carter? 1971 HP 383 with A/C [Re: sunroofgtx] #1279420
08/21/12 08:07 PM
08/21/12 08:07 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
LOL LIST 4735..wait until you try and find one! like NON EXISTENT... and big big $$$$$ SOLD 1 for 550.00 a few yrs ago...RARE RARE
Yep, and of the several hundred carbs that have come and gone from my inventory over the years I have seen exactly one (1) single example that's been available for sale, it's customer owned and still sitting here. He wants a ton for it but rightfully so, they are likely one of the rarest Holleys you'll ever have to find if you need one.
Re: Holley or Carter? 1971 HP 383 with A/C [Re: ScottSmith_Harms] #1279421
08/21/12 09:42 PM
08/21/12 09:42 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Scott how about a holley 4667? I have an early built 71 Bee W/O fresh air, and on the build sheet it has a 48 for carb. Well if I am doing this properly and I believe that I am the 48 is the last two digits of the Part# of the carb which is 3512848. That part# translates to a Holley R4667A. Have you ever seen one or know where I could find one? I could never find one and opted for the Factory Service Manual list# of 6191. Would love to find the right carb as it is a very original car. This Carb question on these 71 383 seems to come up here often. I seem to hear something new everytime that it does!!
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 340cpe] #1279422
08/21/12 11:15 PM
08/21/12 11:15 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
All great info.
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 340cpe] #1279423
08/22/12 12:02 AM
08/22/12 12:02 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This is my latest list of available customer owned Holley carb cores. These are not mine, prices vary depending on what the owners want for them. I do not sell these cores as is, only as restored units. Some are pretty rough and will require another core carb to scavenge good parts from.
4735 -2190
4668 -2020 Body Only
4367 -0389
4367 -3569 Body Only
4737 -1200
4749-3 2095 Body Only
6191 -1271
4749-3 -1190
6191 -2580
4749-3 -1789
6191 -2780
4749-1 -1082 Top Bail Broken
4668 -2550
4668 -1821
6193 -2730
3918 -2017
4368 -2819
6191 -2580 Top Bail Broken
4366 -0780
4749-2 -3392
4217 -2809
6169 -3170 Body Only
4749-3 -0700
4368 -2679
3918 -2357
4166 -3148
1850-2 -3028
4367 -2619
3667-1 963 Part# 2843151
4749 -0224
4367 -3539
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 340cpe] #1279424
08/22/12 12:20 AM
08/22/12 12:20 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
What is the SPD of your Bee? I have a super early one of these that Scott restored for me, I think it may be the only one on the planet. It is dated 0540. Holley does not even list this carb in their carb guide book, and they made it! Scott has a bunch of pictures of it that he could post. I am out of town right now so I can<t post any.
Re: Holley or Carter? 1971 HP 383 with A/C [Re: ScottSmith_Harms] #1279425
08/22/12 12:24 AM
08/22/12 12:24 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
4735 -2190
4367 -0389
4737 -1200
6191 -1271
4749-3 -1190
6191 -2580
4749-3 -1789
6191 -2780
4668 -2550
4668 -1821
6193 -2730
3918 -2017
4368 -2819
4366 -0780
4749-2 -3392
4217 -2809
4749-3 -0700
4368 -2679
3918 -2357
4166 -3148
1850-2 -3028
4367 -2619
4749 -0224
4367 -3539
i have:
LIST 6191 x 2 [2260 & 2280]
LIST 6193 [2370]
LIST 4737 [0120]
71 4 speed idle solenoid also almost NOS
Re: Holley or Carter? 1971 HP 383 with A/C [Re: ph23vo] #1279426
08/22/12 01:48 AM
08/22/12 01:48 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's Dwights 4667, I don't have the after resto pics but here's proof they exist!
Re: Holley or Carter? 1971 HP 383 with A/C [Re: ScottSmith_Harms] #1279427
08/22/12 01:49 AM
08/22/12 01:49 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: Holley or Carter? 1971 HP 383 with A/C [Re: ScottSmith_Harms] #1279428
08/22/12 07:57 AM
08/22/12 07:57 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Watch it Scott. The black Suburbans are rolling your way !!.. Nice
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 71383beep] #1279429
08/24/12 07:06 AM
08/24/12 07:06 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
I see...cool...good to know!
What line on the BS is the carb listed on?
I am guessing it was likely a holley carb. I now know that the engine and trans have been out and it looks like some work was done to it. The car is fairly close to original though and I am wrestling with either going in that direction or "upgrading".
I have no issues with putting a holley on her as i am much more familiar with tuning them, but I am hesitant to put such a rather small one back on.
I have been leaning to a correct 440 AVS like the 4968S if I can find one.
i have one a 4968 avs
i looking for a 4967 avs
holley 4160 are
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: Holley or Carter? 1971 HP 383 with A/C [Re: ScottSmith_Harms] #1279430
08/24/12 08:49 AM
08/24/12 08:49 AM
IL
71383beep Offline
71383beep  Offline
IL
4735 -2190
4367 -0389
4737 -1200
6191 -1271
4749-3 -1190
6191 -2580
4749-3 -1789
6191 -2780
4668 -2550
4668 -1821
6193 -2730
3918 -2017
4368 -2819
4366 -0780
4749-2 -3392
4217 -2809
4749-3 -0700
4368 -2679
3918 -2357
4166 -3148
1850-2 -3028
4367 -2619
4749 -0224
4367 -3539
Okay,
Sorry for a what is probably a dumb question, but what is the second series of digits symbolize?
Thanks,
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 71383beep] #1279431
08/24/12 10:44 AM
08/24/12 10:44 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The second series is the carb assembly date code, 3 digits are the day of the year, last digit is the year)
Re: Holley or Carter? 1971 HP 383 with A/C [Re: ScottSmith_Harms] #1279432
08/26/12 09:32 PM
08/26/12 09:32 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
M46rat what do you have that 4667 on? My SPD of my Bee is August 7th 1970. As I said earlier per the build sheet it should have the 4667. I have the 6191 but the dte on it is late July of 70. The Carb is about the only major component that is not right on the car.
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 340cpe] #1279433
08/26/12 11:26 PM
08/26/12 11:26 PM
m46rat Offline
m46rat  Offline
It is sitting in a cozy box in my basement. An important difference between it and a 6191 is that the base has no provision for the solenoid. My only 71 383+4 car is a Barracuda convertible with an SPD of June 1, 1971. I have a 6191 for it, also done by Scott.
Re: Holley or Carter? 1971 HP 383 with A/C [Re: m46rat] #1279434
03/29/13 01:50 PM
03/29/13 01:50 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i have: 70-71 HOLLEY N96 SHAKER ram air carbs..
LIST 6193 [2370]
LIST 4735 x 2 [2020 & cant rem]
LIST 4737 [0120]
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 71383beep] #1279435
03/29/13 06:07 PM
03/29/13 06:07 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
My 71 AG RR had a holley. On the lean bog thing, mine did the same thing, and I remember that there was a plastic ramp that worked the accelerator pump or something and a grove had wore in it so the pump didn't keep up with the demand, it lagged behind on it pumping action.
