Holley or Carter? 1971 HP 383 with A/C #1279397
08/04/12 09:56 PM
08/04/12 09:56 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
So on my 1971 b body 383 HP, a/c, 727 what came factory? The Holley or Carter?
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Holley or Carter? 1971 HP 383 with A/C [Re: TX9H6E4CUDA] #1279398
08/04/12 10:02 PM
08/04/12 10:02 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
All '71 383 4bbl E & B-bodies were HP orange & HOLLEY.
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 6bblgt] #1279399
08/04/12 10:06 PM
08/04/12 10:06 PM
minnarusta
minnarusta
Excellent thank you for the help!!! Now I gotta fix the Holley I have (its kinda rough but very restoreable).
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 6bblgt] #1279400
08/06/12 06:58 PM
08/06/12 06:58 PM
IL
71383beep Offline
71383beep  Offline
IL
Really?
What about early build N96 & N97 equiped cars w/o AC?
I have what is believed to be the original 650 AVS in a box from the RR I just picked up and the car has not been touched very much from what I can tell.
On the car now is one of the 440 AVS's I believe. I gotta check the #'s.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 71383beep] #1279401
08/08/12 01:52 PM
08/08/12 01:52 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
My 71 RR with air grabber hood and no A/C had a Holley originally..
I am truckless..
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 340SHORTY] #1279402
08/08/12 04:41 PM
08/08/12 04:41 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Early build N96 cars would have a Holley 6193
Re: Holley or Carter? 1971 HP 383 with A/C [Re: YYZ] #1279403
08/10/12 12:59 AM
08/10/12 12:59 AM
IL
71383beep Offline
71383beep  Offline
IL
Okay good to know. The intake has got to be the same though...right? I thought Holley and the Carter's had different mount patterns.
Does N97 make a difference?
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 71383beep] #1279404
08/16/12 03:56 PM
08/16/12 03:56 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
No, no difference. However, Galen's book lists 71 HP 383's to have Carter AVS carbs, part number on the build sheet as #44. My 71 Satellite with the N code HP 383 with 4 speed and A/C, lists the Holley R4667 , part number 48 on the build sheet. Same 4160 Holley with or without A/C. The book does not list it as an HP, but it is. Galen's book is confusing with listing the Carter 6125S for the 71 383 HP's.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Holley or Carter? 1971 HP 383 with A/C [Re: sunroofgtx] #1279405
08/16/12 08:01 PM
08/16/12 08:01 PM
IL
71383beep Offline
71383beep  Offline
IL
This topic has piqued my interest.
The carb on my 383 AG car now is a AVS model 4966S which the FSM lists as standard for the non HP 440 w/ auto.
The FSM also lists the 6125S as std. for 383 with auto as well without a reference as to HP or not. So they did put them on some 383's apparently.
However, for the 4160 Holley the FSM lists the following for 383:
R-6191A and R-4668A for manual/auto respectively with the Heated air intake system
R-6193A and R-4735A for manual/auto respectively with the Fresh Air Intake system (Air Grabber)
So it appears that holley is correct for my application.
However, I have heard from the mopar rumor mill that it was common for dealerships to replace the Holley's with AVS's under warranty because apparently there were a lot of leakage and heat related problems with the Holley's. I am not sure on numbers and what carb was used, but I have heard this from multiple sources.
So...do I keep the AVS and call it a day 2 warranty mod or should I try and hunt down a 4735A Holley?
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 71383beep] #1279406
08/16/12 08:12 PM
08/16/12 08:12 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you have your broadcast sheet go by the number it reflects
Re: Holley or Carter? 1971 HP 383 with A/C [Re: ScottSmith_Harms] #1279407
08/16/12 08:31 PM
08/16/12 08:31 PM
IL
71383beep Offline
71383beep  Offline
IL
Hey Scott! Thanks for coming in...I was considering calling you on this.
Unfortunately I don't have the BS. Its an LA car...of course I have not pulled the seats yet.
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 71383beep] #1279408
08/16/12 08:49 PM
08/16/12 08:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I wouldn't go carb shopping until you've exhausted your Broadcast Sheet search, some LA cars had sheets!
That said, if it was sold new in CA it most likely had the Holley
Re: Holley or Carter? 1971 HP 383 with A/C [Re: TX9H6E4CUDA] #1279409
08/16/12 09:16 PM
08/16/12 09:16 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
My friend who worked at a Plymouth dealership in 1971 said they repeatedly replaced the Holley's with a "conversion kit" 71 AVS 6125S. If you have an air conditioner engine carb, it has the hot idle compensator bar in it as well. Maybe Air Grabbers as well. I think that's what its called.
Re: Holley or Carter? 1971 HP 383 with A/C [Re: sunroofgtx] #1279410
08/16/12 10:40 PM
08/16/12 10:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1971 - factory installed - 383 4bbl automatic
it's pretty straight forward C body OR B&E bodies
if B&E body it's "fresh air" OR "non-fresh air"
383 automatic - C-body blue engine ---------- Carter 6125S ---------- part number 3512 844 on b'cast 44
383 automatic - E & B-body orange HP engine ---------- Holley R4668A ---------- part number 3512 830 on b'cast 30
383 automatic - E & B-body - with "fresh air" (N94/N96) orange HP engine ---------- Holley R4735A ---------- part number 3512 842 on b'cast 42
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 6bblgt] #1279411
08/16/12 10:59 PM
08/16/12 10:59 PM
IL
71383beep Offline
71383beep  Offline
IL
I see...cool...good to know!
What line on the BS is the carb listed on?
I am guessing it was likely a holley carb. I now know that the engine and trans have been out and it looks like some work was done to it. The car is fairly close to original though and I am wrestling with either going in that direction or "upgrading".
I have no issues with putting a holley on her as i am much more familiar with tuning them, but I am hesitant to put such a rather small one back on.
I have been leaning to a correct 440 AVS like the 4968S if I can find one.
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 71383beep] #1279412
08/16/12 11:14 PM
08/16/12 11:14 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
If you decide on a 4968 I may have a line on one.
Re: Holley or Carter? 1971 HP 383 with A/C [Re: ScottSmith_Harms] #1279413
08/16/12 11:23 PM
08/16/12 11:23 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
The 4968 is for a 440 HP auto. Is that what you need? I thought you needed one for your 383? The 4968's are big money. Scott, are you sending one to Mike R?
Re: Holley or Carter? 1971 HP 383 with A/C [Re: sunroofgtx] #1279414
08/17/12 12:54 AM
08/17/12 12:54 AM
IL
71383beep Offline
71383beep  Offline
IL
I am considering it. I am either considering the stock approach or possibly go for the "day 2" concept where it was an old school trick to swap on a 440 carb for some more get em up.
Right now I actually have 2 4966's
The one on the car is actually pretty decent. My only complaints are that whoever tuned it before did not tune the mixture evenly which has left a slight flutter at light loading and I get a pretty noticeable lean bog if you mash it. The car has definitely been babied. If you are light on the throttle she will putter right along all day and even get up if you gently open it up.
Scott you don't have a Holley 4735 do you? Are they decent carbs if rebuilt properly? I think 625 cfm is small for a 383 IMHO.
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 71383beep] #1279415
08/17/12 01:32 AM
08/17/12 01:32 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
LOL LIST 4735..wait until you try and find one! like NON EXISTENT... and big big $$$$$ SOLD 1 for 550.00 a few yrs ago...RARE RARE
Re: Holley or Carter? 1971 HP 383 with A/C [Re: 71383beep] #1279416
08/17/12 01:55 AM
08/17/12 01:55 AM
Shoreline, Washington
72roadrunnergtx Offline
I will provide further first hand back-up of the existence of factory provided Carter conversion kits for the Holley 4160 applications, performed the conversion many times myself during my time at dealers back then. They were packaged as complete kits, fuel lines, choke springs, any other hardware required, fully covered if under warranty. Installed correctly, appeared completely factory installed. Can’t tell you just how many 4160’s wound up in the trash, considered pure junk then by those who serviced them and many under hood fires were blamed directly on them.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
