904- Lost 2nd Gear, Quick fix?
#1279247
08/04/12 03:54 PM
08/04/12 03:54 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Last night the factory 904 lost second gear. It shifts from 1st to 3rd. If the shifter is in 2nd position then there is nothing. Drained the fluid, changed fitler, fluid and added a quart of TransX. Is there something else that can be done to get it through the driving season?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 904- Lost 2nd Gear, Quick fix?
[Re: dfsmopars]
#1279249
08/04/12 04:14 PM
08/04/12 04:14 PM
Posts: 27,168 Rio Linda, CA
John_Kunkel
Rio Linda, CA
2nd gear is a function of the kickdown (front) band, if adjusting it doesn't bring back 2nd gear there is something broken or missing.
[Re: John_Kunkel]
#1279251
08/04/12 05:21 PM
08/04/12 05:21 PM
Posts: 15,493 Florida
scratchnfotraction
I have done this a few times with my junk.
its done when there is no more adjustments.
I have also drove from Fl to Arkasas then back with 1st and 3rd then adjust it to get 2nd back for one last run at the strip before it was toast.
[Re: John_Kunkel]
#1279252
08/04/12 10:06 PM
08/04/12 10:06 PM
dfsmopars
Kentucky
When I had the pan off today all I saw in it was very small pieces of what I believe to be clutch material. I have a manual that probably tells me how to adjust bands- I'm guessing it is no big deal to do? I serioulsy doubt this transmission has ever had the bands adjusted so hopefully there is some adjustment available.
[Re: dfsmopars]
#1279253
08/05/12 12:52 AM
08/05/12 12:52 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Torque the adj screws to 72 inch pounds.. Back them out 2 full turns.. Lock down the nuts.. Test drive. Hopefully you fixed it..
I am truckless..
[Re: dfsmopars]
#1279255
08/06/12 11:04 AM
08/06/12 11:04 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
glad it worked out. I had broken a band on my 904 years ago...that was no fun
