oil spewing from the carb #1278540
08/02/12 08:47 PM
08/02/12 08:47 PM
skelator Offline OP
skelator  Offline OP
hey guys i got my new 440 and im getting oil comming from the carb and getting onto the drop base of the air filter. i got a pcv valve and a breather setup. my pcv valve rattles fine. is there a different setup i should be running or something?
Re: oil spewing from the carb [Re: skelator] #1278541
08/02/12 09:50 PM
08/02/12 09:50 PM
It sounds like your new 440 doesn't have very good ring seal, if it is blowing oil into the air cleaner through the breather hose from the oil breather cap on the valve covers
Re: oil spewing from the carb [Re: Cab_Burge] #1278542
08/02/12 09:59 PM
08/02/12 09:59 PM
skelator Offline OP
skelator  Offline OP
should i do anything or should i be calling my engine builder?
Re: oil spewing from the carb [Re: skelator] #1278543
08/02/12 10:05 PM
08/02/12 10:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is your PCV hose mounted in the air cleaner base
Re: oil spewing from the carb [Re: MR_P_BODY] #1278544
08/02/12 10:12 PM
08/02/12 10:12 PM
skelator Offline OP
skelator  Offline OP
the hose runs from the pcv into the base of the carb in the back. this is correct isnt it?
Re: oil spewing from the carb [Re: skelator] #1278545
08/02/12 10:16 PM
08/02/12 10:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes... some aftermarket stuff has the line going into
the filter base..... yes you should be talking to
the builder.... see what he has to say
Re: oil spewing from the carb [Re: MR_P_BODY] #1278546
08/02/12 10:22 PM
08/02/12 10:22 PM
skelator Offline OP
skelator  Offline OP
i prolly got 200 miles on it if i had to guess.
Re: oil spewing from the carb [Re: skelator] #1278547
08/02/12 10:45 PM
08/02/12 10:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Try beating on it some..... might help seal the rings
IF thats where its coming from
Re: oil spewing from the carb [Re: MR_P_BODY] #1278548
08/02/12 11:11 PM
08/02/12 11:11 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
some valve covers dont have very good baffles, some none at all
Re: oil spewing from the carb [Re: sixpackgut] #1278549
08/02/12 11:18 PM
08/02/12 11:18 PM
skelator Offline OP
skelator  Offline OP
i got chrome edelbrock ones. they both have baffles dunno if their good or bad. tomorrow im gonna get another breather and just run two of them and lose the pcv. gonna try to get these rings to seat.
Re: oil spewing from the carb [Re: skelator] #1278550
08/02/12 11:21 PM
08/02/12 11:21 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
what kind of oil do you have in it ?
Re: oil spewing from the carb [Re: VernMotor] #1278551
08/03/12 07:30 AM
08/03/12 07:30 AM
skelator Offline OP
skelator  Offline OP
brad penn 10-30
Re: oil spewing from the carb [Re: skelator] #1278552
08/03/12 01:31 PM
08/03/12 01:31 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Plug the PVC and run a breather hose into a container to find out how much oil you are losing.
