Stealth spark plugs #1278324
08/02/12 04:13 PM
08/02/12 04:13 PM
skelator Offline OP
skelator  Offline OP
Hey guys I wanna pick up some new plugs for my 440 with stealth heads. What do you guys recommend?
Re: Stealth spark plugs [Re: skelator] #1278325
08/02/12 04:34 PM
08/02/12 04:34 PM
Cab_Burge Online work
Cab_Burge  Online Work
What size motor, mechanical (calculated)compression ratio, fuel type and intended use?
Re: Stealth spark plugs [Re: Cab_Burge] #1278326
08/03/12 08:48 AM
08/03/12 08:48 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 440 with 12.5 domes I run NGK R5671A-8s.I ran Autolites and went to NGKs 3 years ago.Still has the same set in.Its street driven and very happy with the NGKs.The Autolites seemed to have a slight miss after some miles.Rocky
Chrysler Firepower
Re: Stealth spark plugs [Re: therocks] #1278327
08/03/12 09:51 AM
08/03/12 09:51 AM
IN
ahy Offline
ahy  Offline
IN
I have used NKG's based on Mancini's chart by compression ration for aluminum heads. No problems.
http://chucker54.stores.yahoo.net/ngkplugs.html
Re: Stealth spark plugs [Re: ahy] #1278328
08/03/12 11:22 AM
08/03/12 11:22 AM
skelator Offline OP
skelator  Offline OP
Not sure on the exact compression but I have stealth heads, flat top pistons with valve reliefs at zero deck. I think the head gaskets were .040 they were just felpros id have to look them up to be sure
Re: Stealth spark plugs [Re: skelator] #1278329
08/03/12 09:05 PM
08/03/12 09:05 PM
IN
ahy Offline
ahy  Offline
IN
Sounds like 10:1 or a bit more. I'd pick plugs based on 10:1.
Re: Stealth spark plugs [Re: skelator] #1278330
08/04/12 01:35 AM
08/04/12 01:35 AM
Try RC9YC or Autolite AR3911 or 3923 or 3933
