Anyone using steel core rubber BB valve cover gaskets?
#1277574
08/01/12 02:46 PM
08/01/12 02:46 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Bought these big block valve cover gaskets off E-bay to try. The are rubber with a steel core. Anyone using them? Opinions, warnings...etc. Should I use any type of sealant with them? Thanks.
Re: Anyone using steel core rubber BB valve cover gaskets?
[Re: KillerBee]
#1277575
08/01/12 06:35 PM
08/01/12 06:35 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
I bought a set off ebay that look just like those. I have mopar performance alumimun covers and im having a hard time getting them to seal on stealth heads. my first attempt i cracked the corner off the valve cover off due to the gasket hanging off the head. I found another cover and i put studs in the head to make sure it was centered correctly and just put it back on last nght. Not sure if its leaking or not yet. The other side sealed ok the first time. I thought they would be nice seeing you can reuse them but they are really narrow inbetween the bolt holes so theres a chance of them not resting on the head and falling inbetween the head and the valve cover. I would put them on dry.
[Re: KillerBee]
#1277576
08/01/12 07:38 PM
08/01/12 07:38 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I used a set that were blue and made by Moroso I think. They sealed fine with no sealer on Eddy heads and Cal custom valve covers.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1277577
08/01/12 07:48 PM
08/01/12 07:48 PM
KillerBee
N.E. Ohio
I'm using stock 516 heads with vintage DC chrome(steel) valve covers. Have studs/nuts. The ones I currently have do look a little narrow. The Moroso ones look a little wider.
[Re: KillerBee]
#1277579
08/02/12 02:05 PM
08/02/12 02:05 PM
Posts: 64 Iowa
GreenBird
Iowa
After flailing around with two different kind of felpro gaskets, one rubber/steel and one cork, I got these Mopar ones to seal correctly. http://www.summitracing.com/parts/DCC-4452091/Rather than blaming felpro, I think I was over-torquing. I set the Mopar ones with a torque wrench at about 3.5 ftlbs and they sealed. I used that Edelbrock gasincinch sealer on both sides of the gasket. I have stealth heads on an RB.
