nice truck
![](/ubbthreads/images/graemlins/thumbs.gif)
thats is an ok set up for the front mount.
can you post a shot of your shackle on the rear of front leafs?
post a shot of the rear springs front and rear shackle and blocks u-bolts.
you could just add a 2" add a leaf into those front springs and they would be flat and not negative arch like now.
a main leaf from a 4x4 front with the spring eyes cut off and then stuck under your main leaf will do about the same thing for the arch.
what are you after? a slight lift or just flat front springs and stay as high as is now?
I would think it has a good ride and is not harsh as most 4x4s are close to bump stops stock.
if you have body lift make sure they stay torqued up, they tend to work loose when off roading a lot with frame flex.
again. nice looking truck.
![](/ubbthreads/images/graemlins/scope.gif)
