Re: Would this cause a vibration?
[Re: astjp2]
#1276900
07/31/12 09:15 AM
07/31/12 09:15 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
well, if the vibration went away with the new mount then you have your answer, did you do a test drive?
[Re: 19SuperBee70]
#1276904
07/31/12 01:10 PM
07/31/12 01:10 PM
Posts: 4,325 St. Louis, Mo
318 Stroker
St. Louis, Mo
I chased a similar problem with my Challenger. I too had a balanced driveshaft, or so I thought. First d-shaft was a cut-down and balanced one. Finally had it checked by another shop...yep, out of balance. Had a brand new one built and balanced by them...yep out of balance... Had a third d-shaft shop rebalance the second one, and the problem was finally solved.
[Re: 19SuperBee70]
#1276907
08/01/12 10:59 AM
08/01/12 10:59 AM
Posts: 309 Hampden, Maine
Procommuter
super street
super street
Hampden, Maine
Since it changes when you push the clutch in I would doubt it is the driveshaft. Many years ago I had a similar situation and I found that the pilot bushing had backed out of the crankshaft so the input shaft and clutch disc where not being held on center, making the assembly out of balance.
Wes
73 Barracuda 440 EFI 4 speed, 144.85 MPH LTA A/FSS Record Holder.
