Wiring problem #1276123
07/29/12 06:34 PM
07/29/12 06:34 PM
SC
Southern Wolf Offline OP
SC
When I turn the car on, the park lights, marker lights, and tail lights come on, which drains the battery with the car running. The light switch has not been turn on in a month. Need help.This is on an ebody
Re: Wiring problem [Re: Southern Wolf] #1276124
07/29/12 07:31 PM
07/29/12 07:31 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
It sounds like you have a ground problem somewhere. Is there a ground strap between the body and the motor?
Re: Wiring problem [Re: TooMany62s] #1276125
07/29/12 07:40 PM
07/29/12 07:40 PM
SC
SC
I am not sure. The motor was put in the car 2 months ago.
Re: Wiring problem [Re: Southern Wolf] #1276126
07/29/12 08:31 PM
07/29/12 08:31 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
translation needed here. are you saying the lights all come on when you start the car withOUT turning the switch to ON?
Re: Wiring problem [Re: mikemee1331] #1276127
07/29/12 08:43 PM
07/29/12 08:43 PM
SC
SC
Yes, you don't have to start the car just turn the ign on. With the switch off
Re: Wiring problem [Re: Southern Wolf] #1276128
07/30/12 09:51 AM
07/30/12 09:51 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
sound like you have some melted wires touching from the ing/acc wires to the headlight wires.
