Hi Guys and Ladies,
I have a 1967 Plymouth B-body with a trunk mounted battery. The battery is not charging properly when the car is driven. We have tested the alternator (2-field) and it is outputting over 14 volts (14.4 volts I believe). When the car is running (idle and 3k rpm), we are only seeing around 13.45 volts at the battery. I do not think 13.45 volts is enough to charge an Optima red-top battery (or any car battery for that matter).
My questions are:
1.) What size positive wire are people running from the front of the car to the battery in the trunk? It appears the wire for this car is 4 gauge, which I think is too small.
2.) The positive wire from the battery is run up to a bulk-head on the firewall (not the factory bulk-head). It appears to be a stud or bolt that the battery wire, starter wire, voltage regulator (I think), and alternator charging wire (12 gauge) all connect to. What are other people using as the wire junction?
3.) A friend of mine has recommended I try an adjustable voltage regulator. Has anyone gone this route? If so, did it work?
Thanks in advance for your advice and input.
