Re: Odd Ring Gear Question
[Re: Jwilli500]
#1275515
07/28/12 11:38 PM
07/28/12 11:38 PM
moparpollack
Lil Herman
Lil Herman
85086
Shouldn't be because there are two multiple flywheel sizes that are matched to a bell housing size.
The torque converters should share the same diameter though.
[Re: moparpollack]
#1275516
07/28/12 11:49 PM
07/28/12 11:49 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
Ooops! I guess I should have specified a 130 tooth, 10.5 clutch version of the manual trans flywheel! Thanks John.
[Re: Jwilli500]
#1275519
07/29/12 06:05 PM
07/29/12 06:05 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Thanks guys! The reason I'm asking about this is that I am thinking of building an engine run stand. I can get(read I have) an empty auto case a lot cheaper than a manual bell housing. If the flywheel would work in it, that would make things easier, and cheaper. Just thinking out loud a bit...
You aren't the first to think like that. The questioned was posed to me by someone wanting to do the same thing , I haven't looked into it though.
[Re: Jwilli500]
#1275520
07/29/12 06:19 PM
07/29/12 06:19 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
727's have a 130-tooth ring gear.
