my 440 build #1275476
07/28/12 10:30 PM
07/28/12 10:30 PM
skelator Offline OP
skelator  Offline OP
hey guys im new here and thought id share my new 440 specs and see what you all think. i got under 200 miles so far. oh and its in a 69 charger.
1972 440 .055 over, 0 deck height bored and honed with torque plates
steel crank ground .010/.010
scat h-beam rods
keith black icon forged pistons flat top w/valve relief
everything was balanced
holley 750 vac sec carb with a 750 proform main body
lunati cam 60303lk
Intake Duration at 050 inch Lift 226
Exhaust Duration at 050 inch Lift 234
Duration at 050 inch Lift 226 int./234 exh.
Advertised Intake Duration 268
Advertised Exhaust Duration 276
Advertised Duration 268 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.494 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.513 in.
Valve Lift with Factory Rocker Arm Ratio 0.494 int./0.513 exh.
Lobe Separation (degrees) 110
street dominator intake & 1/4" 4 hole phenolic spacer
stealth aluminum heads no work done but they were checked out by my shop i did upgrade the locks
msd 6al and 8.5 super conductor wires, blaster 2 coil, ngk plugs
mopar perf electronic distributor w/ vacuum plugged off
carter street fuel pump, 3/8 fuel line
hemi 6q oil pan, milodon windage tray
melling hv oil pump
stock rockers w/new 5/16 pushrods
crappy hedman headers for now
3" exhaust with x pipe, ultraflows and dougs electric cutouts
4.10's in the dana and a 4 speed
i plan to hit the dyno at some point. any guesses to the #'s?
im also considering a doublepumper. in the near future i wanna get the heads ported and get new tti headers. prolly a different cam after the heads get ported. so i would have to get a carb that would work on the motor now and after the upgrades.
Re: my 440 build [Re: skelator] #1275477
07/28/12 10:45 PM
07/28/12 10:45 PM
IN
ahy Offline
ahy  Offline
IN
Sounds like a well thought out build... should be loads of fun. How does it drive?
Re: my 440 build [Re: ahy] #1275478
07/28/12 10:52 PM
07/28/12 10:52 PM
Welcome to the board.
Re: my 440 build [Re: ahy] #1275479
07/28/12 10:54 PM
07/28/12 10:54 PM
skelator Offline OP
skelator  Offline OP
thank you, a buddy from another board pretty much picked out everything so i cant take credit. she runs real good but im having issues with the secondaries. they appear to be not opening at all after doing the paper clip trick. i might just replace the diaphram and see if that changes anything. that or get a doublepumper haha.
Re: my 440 build [Re: skelator] #1275480
07/28/12 11:09 PM
07/28/12 11:09 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Yeah, don't be afraid of sticking a 850 double pumper on it. It will like it.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: my 440 build [Re: 71yelladustr] #1275481
07/29/12 02:14 AM
07/29/12 02:14 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Welcome. My old 440 build was close to yours but I used ported 906 heads. I would think you will be in the 475 hp area at the flywheel. Good luck. Ron
Re: my 440 build [Re: skelator] #1275482
07/29/12 02:49 AM
07/29/12 02:49 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Welcome.....Sounds like a nice strong build and I would hope for close to 500hp and tq...............
Re: my 440 build [Re: Thumperdart] #1275483
07/29/12 03:26 PM
07/29/12 03:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
should run good. The Proform actually makes your carb flow 823cfm. And don't worry anout those 1 3/4" headers, I run 11.30's w/ them. go have some fun.
Coming soon!!!!
Re: my 440 build [Re: Mr.Yuck] #1275484
07/29/12 05:35 PM
07/29/12 05:35 PM
skelator Offline OP
skelator  Offline OP
what do you guys think she would run in the 1/4? i think im gonna pick up that proform doublepumper.
Re: my 440 build [Re: skelator] #1275485
07/30/12 10:20 PM
07/30/12 10:20 PM
Central NC
gch Offline
gch  Offline
Central NC
Cam is a bit small for your gear IMO but should have tons of mid range and rpm quick.
Headers are fine for a street car.
Porting the heads would'nt hurt.
I would get the carb dialed in first.
Then change one thing at a time so you know what works/doesent work.
A 750 is fine for your cam and headflow.With ported heads and/or one size larger cam I might consider an 850 DP with a 4 speed and 4.11 gears.
Re: my 440 build [Re: gch] #1275486
07/31/12 12:39 AM
07/31/12 12:39 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You get it dailed in it can run mid 11's. I used the 1-3/4 headers on my old 440 and it ran 11.49 @ 116 best. They worked fine for my street car with mild heads. I went to 2" with this eng but I use EZ heads on this eng. You will be fine with the 1-3/4. Ron
