Re: New torsion bars for 70 Challenger
[Re: jsully]
#1275263
07/28/12 11:39 AM
07/28/12 11:39 AM
Posts: 4,848 Memphis
HemiRick
Memphis
They should be straight. A slight bow probably will not matter.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: jsully]
#1275266
07/28/12 02:48 PM
07/28/12 02:48 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
I received new torsion bars from Mancini (MP .960") to install this weekend. I understand the rt / lt and front to back discussions and figured that out. My question is; the left bar (#785) has a slight bow in it. Is this coincident or design? And, does the bow 'face / rise' up(I assume it does)? I am replacing a set of 1" Just Suspension 'touring' bars that have a lowering offset (too low for me -even after adjusting all the way up). Thanks
how low was too low? I'm interested is some larger bars and my charger is pretty low in the front by choice so maybe a good choice for me. although I read in this section that their 1" bar really isn't, it's smaller.
[Re: jsully]
#1275270
07/29/12 11:46 AM
07/29/12 11:46 AM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
That's weird? I have JS bars in mine too and they work/fit great. The adjuster is at about half way when installed at ride height. I have the bars hanging in the crossmember sockets at the moment as I'm doing an engine swap and the hex is not flat to flat. They are indexed. One sits flat and the other end sits on a hex point? Do yours have the JS logo in the end of the bar? I have 1.120" bars coming from firm feel to see how I like it. FYI the 1" bars are a soft ride IMO. But I have a BB. I bought them about 2-3 years ago if that factors into anything?
[Re: Pale_Roader]
#1275275
07/30/12 07:31 PM
07/30/12 07:31 PM
Posts: 804 central CT
cudazappa
central CT
I bought my Just Suspension 1" bars in late 2009 early 2010. Both bars were indexed 30* making each one useable on both sides. I've had no problem with adjustments, currently the car sits at about stock ride height.
1971 Challenger
[Re: cudazappa]
#1275276
07/30/12 09:11 PM
07/30/12 09:11 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
I'm at the stage where everything is going back together with the latest being the engine and tranny being installed. With these items, we loaded the suspension and adjusted to set the height. Come to find out the adjuster screws are in just enough and stick far out. The bars are installed left and right correctly. Talking with the vendor abiout the hex indexing and they believe my bars are mis labelled / stamped wrong. The Right is the left and the left is the right. I'm guessing I'm going to have to bite the bullet and swap them and prayed to the Blessed Mother of Rapid Acceleration that this works.
Common sense is a flower that does not grow in everybody's garden
[Re: Ron_M]
#1275277
07/30/12 09:19 PM
07/30/12 09:19 PM
Ron_M
Connecticut
Quite maddening all that effort and we cannot achieve the height we want. I realize the bars need to settle and they're beefier than stock. I really hope switching them works so the screw adjusters are more engaged. I could have the bolts shortened, but it's roll the dice if that will be of any significant help. Gut tells me to swap the bars but I'm not a suspension expert. Hate to hit a dead possum with those adjusters. Already wrecked my Moroso 8 quart pan which started this business. ![](/ubbthreads/images/graemlins/fan.gif)
[Re: AndyF]
#1275279
07/30/12 10:19 PM
07/30/12 10:19 PM
Ron_M
Connecticut
Understood. I have been in contact with the vendor. I'm not naming them as we are working it out but the swapping side to side was a recommendation. I'm not bashing them.
Gonna have to dig the old bars out.
I sent you an email on another issue.
Sorry to steer off topic...
