What thickness is the Milodon water pump spacers? #1274982
07/27/12 04:05 PM
07/27/12 04:05 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
I just installed a Milodon gear drive and found out when I went to bolt on the water pump that I need spacers. I was going to mill up some but need to know the thickness? 3/8" ?
Thanks Brad
Re: What thickness is the Milodon water pump spacers? [Re: brads70] #1274983
07/27/12 04:08 PM
07/27/12 04:08 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I measure them in a couple minutes when I go to the garage. I got two sets here!
think I measured them when i was installing my engine plate .200 comes to mind but i'll know soon!
Re: What thickness is the Milodon water pump spacers? [Re: brads70] #1274984
07/27/12 05:18 PM
07/27/12 05:18 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Since you are Canadian 7.87 mm :-)
Re: What thickness is the Milodon water pump spacers? [Re: Dodgem] #1274985
07/27/12 05:19 PM
07/27/12 05:19 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
.310 in English guess my memory was not good thinking .200???
Re: What thickness is the Milodon water pump spacers? [Re: Dodgem] #1274986
07/27/12 07:59 PM
07/27/12 07:59 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Thanks ! I got ambitious and made my own . Turned out 3/16" ( .187) was a perfect fit. I couldn't believe they wanted over $40 for them?
Re: What thickness is the Milodon water pump spacers? [Re: brads70] #1274987
07/27/12 08:48 PM
07/27/12 08:48 PM
Make them .250,1/4 inch and have the back side water pump housing that mates to the block machined 1/4 inch also, all the pulleys will line up that way
Re: What thickness is the Milodon water pump spacers? [Re: Cab_Burge] #1274988
07/27/12 10:51 PM
07/27/12 10:51 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
If I did that it's the same thing as not having the spacer? I suspect you meant, use a 1/4" spacer then take off .060" off the water pump.
Turns out the back of the water pump was just touching the timing cover when I assembled it all again to check clearances. So I milled .030" off the back of the pump. That and when I install the gaskets I'll be good to go!
