Re: E body electric fuel pump mounting location
[Re: 70VcodeCoronetRT]
#1274593
07/26/12 08:20 PM
07/26/12 08:20 PM
Posts: 3,334 West Coast, USA
jbc426
West Coast, USA
This is the only pump I found that is rated for continuous duty AND is able to be mounted above the fuel tank level. It's from Product Engineering. http://www.product-eng.com/default.htmlI used the factory trunk holes to run the lines. Having the fuel pump in the trunk helps keep it clean and dry too.
1970 Plymouth 'Cuda #'s 440-6(Stock drivetrain in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's & EFI. 1968 Plymouth Barracuda Convertible Paxton Boosted 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1274594
07/27/12 07:41 AM
07/27/12 07:41 AM
Posts: 13,650 Marion, South Carolina [><]
an8sec70cuda
Mine is mounted on the inside of the frame, passenger's side next to the stock tank...no tailpipes. When I did have tailpipes I had it on the outside of the frame. Aeromotive A1000 pump. ![](/ubbthreads/images/graemlins/thumbs.gif)
CHIP '69 road runner, 440-6, 4 speed, Dana 60 '70 'cuda, 575" Hemi, 727, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax '17 Ram 1500 5.7 Hemi
