Page 1 of 3 1 2 3
EFI Gas tank options for handling? #1274279
07/26/12 04:09 AM
07/26/12 04:09 AM
moparAL Offline OP
moparAL  Offline OP
Please don't re-list my post in another section. What options are available for a baffled gas tank for a 70 EFI Challenger. I have looked at ads from Rock Valley, Ricks gas tanks, Modern Muscle, Hot-rod City, XV Motorsports, and others. I am setting up my car to handle well and don't want to worry about fuel starvation going around corners. I have read some Chevy forms about this and most like Ricks stainless tanks (vapor works version with 2 fuel pick ups) great idea, but silly expensive. Mopar guys that autocross what ways have you dealt with this issue? I need a new tank anyway so what do you suggest?
Re: EFI Gas tank options? [Re: moparAL] #1274280
07/26/12 04:46 AM
07/26/12 04:46 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The simplest and least expensive option is use any tank full, if extra weight is an issue, use a smaller full tank, most other options that allow you to run from a full tank down to The last drop use internal trap door sumps and cost a few bucks. Whats your intended use?
Re: EFI Gas tank options? [Re: moparAL] #1274281
07/26/12 08:42 AM
07/26/12 08:42 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
mine is just a street car, but after researching a few the hot rod one needs a new sending unit, filler tube adapted, etc.
The rock valley unit was a bolt in deal, that added a spiral around the pump = I have driven it under 1/8th of a tank and cant get it to starve - i doubt you could sustain corners for an extended amount of time but i;ve been completely happy with my purchase.
Re: EFI Gas tank options? [Re: DJVCuda] #1274282
07/26/12 08:42 AM
07/26/12 08:42 AM
East Tennessee
Burkenator Offline
Burkenator  Offline
East Tennessee
Rock Valley as well. Works great.
Re: EFI Gas tank options? [Re: Burkenator] #1274283
07/26/12 01:01 PM
07/26/12 01:01 PM
moparAL Offline OP
moparAL  Offline OP
This is the type of feedback I am looking for. Yes, the cheapest solution is to run close to a full tank. If I get down to say 1/8 of a tank and I don't want fuel starvation I want to be prepared. There are several members that run auto cross and a ton members that drag race what do you do with regards to fuel starvation? Steve, Autoxcuda any thoughts?
Re: EFI Gas tank options? [Re: moparAL] #1274284
07/26/12 01:16 PM
07/26/12 01:16 PM
Truck Y'all ! Offline
Here's what I did in my '68 A-body (Valiant). Just submitting this for reference...
I found a huge (32 Gallons!) Jaz fuel cell that would fit between frame rails and went for it. This way, I could run just a little bit of fuel or a full tank for touring and be all set.
Here's the one I used: "PART # 286-432-06
Designed to fit between the frame rails of 1984-2001 Jeep Cherokees. 32 Gallon fuel cell with a 45 degree 2-1/2" Fill Valve and Oval Fill Plate. Also includes cast aluminum Bat Wing pick-up, -10 Tip Over vent, -8 Return Fitting and -8 Pick-up. This fuel cell is also foam filled. Great for Truck Pre-Runners!"
Re: EFI Gas tank options? [Re: moparAL] #1274285
07/26/12 01:18 PM
07/26/12 01:18 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
When I sell EFI systems to the "rock crawler" guys they have the same problem, only worse, because they can sit at weird angles for a long time.
So the ultimate solution, that's also fairly inexpensive, is to use a tall narrow intermediate tank. This approach allows you to keep the stock tank since it only used as a reservoir.
One local guy fit the intermediate tank in the front of his trunk. He can now run down to the last drop while sitting at a 45 degree angle.
Re: EFI Gas tank options? [Re: moparAL] #1274286
07/26/12 01:24 PM
07/26/12 01:24 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I've autocrossed my Chall T/A since 1975 in the SCCA Solo II events... car is currently nationally prepared to run in class E/Street Prepared (since its class inception ~1986). Although I've always run a mechanical fuel pump, I've never had any fuel starvation problems.. In fact, I've always preferred to run the auto-x events with as little weight as possible... typically starting the event's day with about 1/3 tank of gas... ending up with about 1/8 tank... tank is factory stock. One note -- if you run a Challenger with more than 1/2 tank of gas, or worse with a full tank, you'll not only have all that extra weight (bad!) but the fuel will probably spill out of the side-filler onto the quarter panels unless you have a very good sealing gas cap, and perhaps wrapped with small cloth soak to it up.... The g-force in such events can be pretty high to force the fuel up the filler and beyond the gas cap... from my experience!
Re: EFI Gas tank options? [Re: Mopar Mitch] #1274287
07/26/12 01:33 PM
07/26/12 01:33 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
it has been my experience that the carb'd motors will not show fuel starvation for brief moments, like going around corners.
a cab has two fuel bowls for reserve in that instance where the pickup cannot get the fuel to the pump -
EFI has no such " reserve" the second the pump has no pressure, the injectors have no pressure as well - no pressure and they do not supply the engine with fuel - it is more instantaneous then with a carb.
Re: EFI Gas tank options? [Re: Mopar Mitch] #1274288
07/26/12 01:35 PM
07/26/12 01:35 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Your Challenger is obviously not fuel injected, I suspect you missed that difference between your setup and the op's.
When I FI'd my Diplomat the in tank pump would suck air at anything under a half tank if I drove it hard. Under a quarter tank it would suck air in almost any turn at any speed above grandma speed.
Same basic tank design. My solution was a small surge tank fed by the mechanical pump, the surge tank would feed the EFI pump.
Don't be the exception.
Re: EFI Gas tank options? [Re: Supercuda] #1274289
07/26/12 04:04 PM
07/26/12 04:04 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I installed one of these at the rear of my aluminum boat tank in my car. And I used a Walbro GSS340 inside of it mounted to one of these.. http://www.tanksinc.com/index.cfm/page/p...prod/prd253.htm and it has so far been flawless.
Mopar to the bone!!!
Re: EFI Gas tank options? [Re: Mopar_Rich] #1274290
07/26/12 04:50 PM
07/26/12 04:50 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Same idea as this!
http://www.ratdat.com/?p=168
Re: EFI Gas tank options? [Re: brads70] #1274291
07/27/12 10:39 PM
07/27/12 10:39 PM
IN
ahy Offline
ahy  Offline
IN
Same idea as this!
Nice way to make a sump! I run "in tank" on my hotrod but am planning a sump on another project. I will likley use the CO2 tank starting point.
Re: EFI Gas tank options? [Re: ahy] #1274292
07/28/12 01:20 PM
07/28/12 01:20 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Here is my set-up. Carter for lift pump, BC Bronco's surge tank fuel filter, and Walbro GSL392. There is a Wix 33737 filter/regulator not in the picture.
Here is the BC Bronco's link:
http://www.bcbroncos.com/store/product_info.php?products_id=119
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: EFI Gas tank options? [Re: 72Swinger] #1274293
07/28/12 01:22 PM
07/28/12 01:22 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Where did you get this? That's a nice set-up!
Re: EFI Gas tank options? [Re: Uhcoog1] #1274294
07/28/12 05:11 PM
07/28/12 05:11 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I got the trap doors from Fuel Safe and had the box made out of aluminum. Your setup should work good too with that big filter. I wanted a bigger tank anyway,mine is now 25 gal,and knew an access door with an in tank pump was always the plan so thats why I chose the route I did.
Re: EFI Gas tank options? [Re: 72Swinger] #1274295
07/30/12 03:34 PM
07/30/12 03:34 PM
moparAL Offline OP
moparAL  Offline OP
Hotrod City Garage has a interesting aluminum EFI tank. It has a lower sump (1 inch lower) at the bottom front of the tank, a internal perforated 5 inch tall open box surrounding the pickup, and internal front and side baffling. They have a choice of pumps, and a drain plug option. What do you think? Picture 1
Re: EFI Gas tank options? [Re: moparAL] #1274296
07/30/12 03:36 PM
07/30/12 03:36 PM
moparAL Offline OP
moparAL  Offline OP
Hotrod City Garage gas tank (right picture), picture 2
Re: EFI Gas tank options? [Re: moparAL] #1274297
07/30/12 03:45 PM
07/30/12 03:45 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Those are nice and are a bolt in option. They were more $$$ than I had available when the time came for my fuel setup.
Re: EFI Gas tank options? [Re: 72Swinger] #1274298
07/31/12 02:00 AM
07/31/12 02:00 AM
moparAL Offline OP
moparAL  Offline OP
Hotrod city garage gas tank picture 3
Page 1 of 3 1 2 3
