Re: EFI Gas tank options?
[Re: moparAL]
#1274280
07/26/12 04:46 AM
07/26/12 04:46 AM
Posts: 22,696 Bitopia
jcc
Bitopia
The simplest and least expensive option is use any tank full, if extra weight is an issue, use a smaller full tank, most other options that allow you to run from a full tank down to The last drop use internal trap door sumps and cost a few bucks. Whats your intended use?
[Re: moparAL]
#1274286
07/26/12 01:24 PM
07/26/12 01:24 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I've autocrossed my Chall T/A since 1975 in the SCCA Solo II events... car is currently nationally prepared to run in class E/Street Prepared (since its class inception ~1986). Although I've always run a mechanical fuel pump, I've never had any fuel starvation problems.. In fact, I've always preferred to run the auto-x events with as little weight as possible... typically starting the event's day with about 1/3 tank of gas... ending up with about 1/8 tank... tank is factory stock. One note -- if you run a Challenger with more than 1/2 tank of gas, or worse with a full tank, you'll not only have all that extra weight (bad!) but the fuel will probably spill out of the side-filler onto the quarter panels unless you have a very good sealing gas cap, and perhaps wrapped with small cloth soak to it up.... The g-force in such events can be pretty high to force the fuel up the filler and beyond the gas cap... from my experience!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#1274287
07/26/12 01:33 PM
07/26/12 01:33 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
it has been my experience that the carb'd motors will not show fuel starvation for brief moments, like going around corners. a cab has two fuel bowls for reserve in that instance where the pickup cannot get the fuel to the pump - EFI has no such " reserve" the second the pump has no pressure, the injectors have no pressure as well - no pressure and they do not supply the engine with fuel - it is more instantaneous then with a carb.
[Re: Mopar_Rich]
#1274290
07/26/12 04:50 PM
07/26/12 04:50 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
When I sell EFI systems to the "rock crawler" guys they have the same problem, only worse, because they can sit at weird angles for a long time.
So the ultimate solution, that's also fairly inexpensive, is to use a tall narrow intermediate tank. This approach allows you to keep the stock tank since it only used as a reservoir.
One local guy fit the intermediate tank in the front of his trunk. He can now run down to the last drop while sitting at a 45 degree angle.
Same idea as this! http://www.ratdat.com/?p=168
[Re: brads70]
#1274291
07/27/12 10:39 PM
07/27/12 10:39 PM
Posts: 7,664 IN
ahy
IN
Nice way to make a sump! I run "in tank" on my hotrod but am planning a sump on another project. I will likley use the CO2 tank starting point.
[Re: ahy]
#1274292
07/28/12 01:20 PM
07/28/12 01:20 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Here is my set-up. Carter for lift pump, BC Bronco's surge tank fuel filter, and Walbro GSL392. There is a Wix 33737 filter/regulator not in the picture. Here is the BC Bronco's link: http://www.bcbroncos.com/store/product_info.php?products_id=119
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#1274294
07/28/12 05:11 PM
07/28/12 05:11 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I got the trap doors from Fuel Safe and had the box made out of aluminum. Your setup should work good too with that big filter. I wanted a bigger tank anyway,mine is now 25 gal,and knew an access door with an in tank pump was always the plan so thats why I chose the route I did.
Mopar to the bone!!!
[Re: 72Swinger]
#1274295
07/30/12 03:34 PM
07/30/12 03:34 PM
moparAL
Hotrod City Garage has a interesting aluminum EFI tank. It has a lower sump (1 inch lower) at the bottom front of the tank, a internal perforated 5 inch tall open box surrounding the pickup, and internal front and side baffling. They have a choice of pumps, and a drain plug option. What do you think? Picture 1
[Re: moparAL]
#1274297
07/30/12 03:45 PM
07/30/12 03:45 PM
72Swinger
Nebraska
Those are nice and are a bolt in option. They were more $$$ than I had available when the time came for my fuel setup.
[Re: wrenchinrandy]
#1274303
08/22/12 02:41 PM
08/22/12 02:41 PM
moparAL
I appreciate all the ideas, but other than Ricks idea (which no one has done with a older Mopar tank yet), the small external sump tank, double pump system, I haven't seen a reasonable priced system and I would not use that on the street! With all the Auto X members I thought you would have solved this issue. Ricks tanks has this tank called a Vaporworx tank. It is stainless inside and out, lots of baffling, and get this multiple fuel pickups. In the Vaporworx ad Mary Pozzi (Auto x driver) tested this tank with much success. But it is stupid, silly, crazy, expensive!
Re: EFI Gas tank options for handling?
[Re: moparAL]
#2785747
06/15/20 02:54 PM
06/15/20 02:54 PM
Posts: 898 Georgia
72440CUDA
Georgia
I wanted to re-visit this post instead of starting a new one (I don't mean to hijack).
What is everyone using for a vent system?
I currently have a Hot Rod City Garage aluminum baffled tank (now out of business?) with an external electric fuel pump. I originally had a vent line routed into the frame rail and it just pissed fuel out (NOT GOOD!) So for the mean time, I've just capped it off (not good either!).
I've been doing some research... want an operating vent as to not cavitate/blow out tank seams with sealed filler cap so it doesn't spill fuel out the back, and I don't want the garage to fill with fumes.
Current plan is to run a vertically mounted in-line roll over valve to a II Much vent mounted in the truck (under the package tray?) at a level higher than the filler neck, with the inlet/outlet mounted externally. Other option is to run a Newton TPV6 valve. Should have about $300 tied into it when all said and done.
Thoughts?
[Re: 72440CUDA]
#2786047
06/16/20 03:00 PM
06/16/20 03:00 PM
Posts: 30,995 Oregon
AndyF
Boyd welding has a slick little adapter plate that allows you to use a factory Ford vent on a custom tank. You could use the Boyd vent plate on a custom expansion tank. Build a one gallon expansion tank and plumb it to the existing vent on your tank and then use the Ford vent on the expansion tank. Or if your existing tank has a vapor dome in it then you could use the Ford vent right in the vapor dome. https://fueltankparts.com/collectio...ucts/ford-oem-vent-weld-in-bung-aluminum
[Re: moparAL]
#2787929
06/21/20 10:42 PM
06/21/20 10:42 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Hotrod city garage, picture 4, of internal baffling. I don't think going to a external efi sump tank in California is legal. I don't want to go with a fuel cell either. This had a lot of features that some of the real big buck tanks have and are cheaper. It is also is made of aluminum. What issues, if any, might a aluminum tank might have? Any more thoughts about this tank? hope i'm not too late for ya - i have one - first the seal leaked as they used the wrong seal for gas (go figure) - would not send me a new one - had to make one up from the local parts store and cut out my own gasket - then had nothing but fuel issues spilling out of the tank - problem is the fuel pump is below the the top of the tank so it always wants to siphon - I had to weld a bung on top of the tank and on the filler neck and install a one way valve in it and add a seperate air vent with a filter on it - the tank is cheap and for these reasons...I bought through some one else (mopardan?) but it was built by hotrodcity garage I should also mention I used a hydromat when I last took out the pump
[Re: dangina]
#2789951
06/27/20 04:40 PM
06/27/20 04:40 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Anybody given any thought to using an evap cystem from a late model vehicle, say 2000 and newer?
Carl Kessel
[Re: AndyF]
#2790292
06/28/20 12:58 PM
06/28/20 12:58 PM
CKessel
Los Osos, Ca
I'm going to check out the components that GM uses for their E-ROD packages. Since those are a retrofit to older chassis, that may be an easy route to take.
Carl Kessel
[Re: CKessel]
#2791886
07/02/20 11:26 AM
07/02/20 11:26 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I use to design fuel tanks and tested them.. the first EFI car was the Imperial the group that did the injection didnt pay any attention to being low on fuel.. once they seen this issue we were given the project to fix it.. after a few weaks we came up with a can inside the tank.. over time we came up with a plastic reservoir in ALL production cars and trucks... still in all.. we called it a swirl can that would use the return fuel to keep the can full.. the pump is inside the can and will drain the tank to about 250 cc or less.. just look at the inside of a newer car or truck EDIT I also did a few company road race sponsored tanks.. they use to have a issue of running out of fuel so we put 4 pick ups in the tanks we built(one in each corner) being that these were carb system they never had a problem.. these tanks HAD to look like a production part.. we had to seam weld the seams on them
[Re: AndyF]
#2796402
07/14/20 08:48 AM
07/14/20 08:48 AM
Posts: 898 Georgia
72440CUDA
Georgia
If the tank doesn't have a vapor dome then you will just have to remember to not fill it full. Or only fill it full when you are driving somewhere. The gas comes out of the ground tank at 60 degrees so on a hot day the gas will expand once it gets into the tank. Without an expansion tank the gas will just push out the vent. I ran into this same issue when I had a fuel cell in a race car. The fuel cell was just a box with no expansion area. I filled it up on a cool day and then on the next hot day I had a mess when gas started to push out the vent tube. This is what I’ve come up with to solve my vent issue. 1 gal fuel cell with built in roll over valve, plumbed using -6an PTFE hose. Should provide some sort of expansion for the fuel coming out the main tank vent port. Mounted on top it the IIMuch vent system. The vent system will then route to a sintered filter mounted to a bulkhead fitting. I haven’t finished mounting the 1gal cell yet but you get the idea. I’ve used body plugs as I didn’t want to drill any unnecessary holes in the trunk. Trunk will eventually be finished with removable panels. The IIMuch system came with a stick on thermometer that I mounted to my fuel tank and it definitely shows how hot my fuel tank gets here in Southern Georgia. [img]http://[/img]
