07/25/12 04:12 PM
07/25/12 04:12 PM
mass
0
03dodgeram Offline OP
mass
I have 67 satellite with a 440 30 over 906 ported heads 509 cam msd ign m1 intake 800 Holley dp. Goes great. I have a 6000 chip in it now,Rev limiter goes off at 6000 very quickly. How high of a chip should i go.Don't want to hurt my baby. Thanks Paul
Re: 440 [Re: 03dodgeram] #1273877
07/25/12 04:22 PM
07/25/12 04:22 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
how sturdy is your bottom end built? valve springs? are you balanced?
Re: 440 [Re: mikemee1331] #1273878
07/25/12 05:03 PM
07/25/12 05:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what are you shifting at? If you are shifting at 6k chip it to 6400. I shift at 64ish, I'm gonna go with a 68oo pill
Coming soon!!!!
Re: 440 [Re: 03dodgeram] #1273879
07/25/12 05:10 PM
07/25/12 05:10 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
best shifts with that cam and heads is 5800 to 6000 chip it at 6200 and aim for 5800 or go with the 6400 chip they soft limit 300 rpms early getting harder till the number.
Re: 440 [Re: mikemee1331] #1273880
07/25/12 06:38 PM
07/25/12 06:38 PM
mass
0
mass
The motor is balanced tha valve springs are 600 lift
Re: 440 [Re: 03dodgeram] #1273881
07/25/12 07:02 PM
07/25/12 07:02 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What kind of rods and pistons? With so-so flowing stockish heads I would probably chip it to 6500 and shift at 6200. Like said already the limiter starts coming in before it's rated rpm so you want to go a bit higher.
Re: 440 [Re: DaytonaTurbo] #1273882
07/25/12 07:27 PM
07/25/12 07:27 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Why do people insist on spinning way past the powerband????
Re: 440 [Re: MoparforLife] #1273883
07/25/12 07:40 PM
07/25/12 07:40 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Same reason as people make bad decisions on cam shafts...
Bigger is better isnt
I am truckless..
Re: 440 [Re: 340SHORTY] #1273884
07/25/12 07:58 PM
07/25/12 07:58 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
thank you!! i didn't know how to say it nicely but really, if you only are making power up to 6000, what's the point of pushing it?? just to test your parts?
Re: 440 [Re: mikemee1331] #1273885
07/25/12 08:14 PM
07/25/12 08:14 PM
Manitoba, Canada
Manitoba, Canada
How do we know what rpm he's making power until? With crap flowing stock heads he's done way before 6k. If nicely ported he could be making power up to there.
Re: 440 [Re: DaytonaTurbo] #1273886
07/25/12 08:48 PM
07/25/12 08:48 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
seat of the pants, my man, seat of the pants! and ported 906's aren't that bad. i run them with big valves and i'm pretty happy!
Re: 440 [Re: 03dodgeram] #1273887
07/25/12 10:22 PM
07/25/12 10:22 PM
God's Country Maryland
GODSCOUNTRY340 Offline
The weak link in the 440 are the 3/8" rod bolts. They are the same as a 318 rod bolt (3/8"). If you rev the 440 over 6,200 RPMs, those heavy pistons really start to stress those 3/8" bolts. They will stretch, opening the rod bearing clearances and let the bearings spin over top each other (piggy back). Keep your RPMs below 6,200 and it will last a long time. Keep spinning it to 6,500 or over, you'll be buying parts real soon.
Re: 440 [Re: MoparforLife] #1273888
07/25/12 10:27 PM
07/25/12 10:27 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Usually for a better et.
Re: 440 [Re: BSB67] #1273889
07/25/12 10:32 PM
07/25/12 10:32 PM
Upper Midwest
Upper Midwest
That usually don't happen because they are spinning too far past the power band and would et better to shift earlier and save on part to boot.
Not with the 509 cam he won't be.
Re: 440 [Re: MoparforLife] #1273890
07/25/12 11:39 PM
07/25/12 11:39 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What are you calling power band? Depending on the set-up, lowest et might be achieved shifting 600 rpm above peak hp.
Re: 440 [Re: BSB67] #1273891
07/26/12 12:17 AM
07/26/12 12:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This brings back memories. I remember some years back my girl griend had a 340 Dart and wanted me to race it for her to see what it would run. Well my brother went with us and I let him drive it first. His first pass was 13.87 @ 104. Afert 4 passes he worked it down to a best of 13.54 @ 105. Now remember this was with street tires that would go up in smoke if not driven right. I jump in the car and made one pass....13.49 @ 105. Well my brother comes up to me kinda ticked off and says ......what did you shift at ?? I said I dont know as I never looked at the tach ! That ticks him off when I do that but it is the truth. I just shifted by the feel as when it felt to be about done in each gear I shift. That makes a good starting point for me and I can play around with shift RPM from there. But many times my seat of the pants was on the money. Ron
Re: 440 [Re: 03dodgeram] #1273892
07/26/12 05:49 AM
07/26/12 05:49 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Torque moves mass. Many times one just has to go to the track and try different rpm levels when shifting to find what makes the car quickest.
As explained to me years ago.......overrevving just cheats the next gear out of seeing some of the torque band it should.
440's are mid-range torque beasts!
Re: 440 [Re: MoparforLife] #1273893
07/26/12 04:50 PM
07/26/12 04:50 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
different animal maybe but i had a 383 w/ a 509 that i shifted at 6800 for best et. It had ported 915 heads, 509 cam, 10.5:1, torker II intake, headers, 750DP I also ran 40* of timing. I listen to a guy once say i had to much timing so I backed it off and it ran 3 tenths slower, I also listen to a guy tell me I was shifting to high so I shifted at 6400 and it went slower... my piont is you can set the car up, but until you drive it hard you won't know what to shift at or how to tune it. go WOT and when you feel it fall off or falten out shift it, that will be your shift point. The 509 cam has an advertised operating rang of 2600-6000rpm. Your shift point can be anywhere from 5800-6400
