single turbo hemi #1273653
07/23/12 07:29 PM
07/23/12 07:29 PM
Wisconsin,USA
Bzzzz Offline OP
Bzzzz  Offline OP
Wisconsin,USA
2005 Dodge 1500 Slt Hemi
2008 Chrysler PT cruiser
1984 Dodge D250
1978 Dodge D100 Adventurer
1964 Meyers Manx Dunebuggy
Re: single turbo hemi [Re: Bzzzz] #1273654
07/23/12 08:24 PM
07/23/12 08:24 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
WOW! I'd do it in a heartbeat.
-Daty
Re: single turbo hemi [Re: Daty Rogers] #1273655
07/23/12 08:32 PM
07/23/12 08:32 PM
Renton Washington
Triple Threat Offline
Renton Washington
Don't expect it to live forever. But it should be fun!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: single turbo hemi [Re: Triple Threat] #1273656
07/23/12 11:42 PM
07/23/12 11:42 PM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
Gives me a lot of hope for my 6.1 that is getting all good parts and a lot more turbo.
Jack Irons Jr. '67 GTX, turbo 6.1 HEMI
Re: single turbo hemi [Re: JackGTX440] #1273657
07/24/12 02:35 AM
07/24/12 02:35 AM
Wisconsin,USA
Bzzzz Offline OP
Bzzzz  Offline OP
Wisconsin,USA
How strong are the blocks.d.5.7-6.1 compared to 400-440?m
with stronger internals would it "live"longer?
1984 Dodge D250
Re: single turbo hemi [Re: Bzzzz] #1273658
07/24/12 03:07 AM
07/24/12 03:07 AM
ScatPackNick Offline
Looks awesome, id go for it.
Re: single turbo hemi [Re: Bzzzz] #1273659
07/24/12 07:20 AM
07/24/12 07:20 AM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
The 6.1 with forged lower end, billet caps and arp fasteners can handle in the neighbor hood of 1100 fwhp, then head sealing issues are supposed to show up. I would say a 5.7 wouldnt be all that far behind, but not exactly sure. My best guess would be a 6.1 could probably safely make near 300 more hp than a B/RB. This is just based on what I've heard from others expirience. We shal see when my 6.1 is finished.
Re: single turbo hemi [Re: JackGTX440] #1273660
07/24/12 11:21 PM
07/24/12 11:21 PM
My N/A single four barrel carb. 400 block pump gas stroker made 627 HP and 710 Ft Lbs on Oregon pump gas in Klamath Falls on a stingy DTS engine dyno with off the shelf parts Better parts make more power,pick your poison
Re: single turbo hemi [Re: Cab_Burge] #1273661
07/25/12 04:34 AM
07/25/12 04:34 AM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
I suppose the the difference between the two is on the genIII, the heads will not seal before parts break, where as with the B/RB you will probably break the block.
Re: single turbo hemi [Re: JackGTX440] #1273662
07/28/12 11:20 PM
07/28/12 11:20 PM
Wisconsin,USA
Bzzzz Offline OP
Bzzzz  Offline OP
Wisconsin,USA
hey guys thanks for the responses
1984 Dodge D250
Re: single turbo hemi [Re: Bzzzz] #1273663
07/29/12 02:08 AM
07/29/12 02:08 AM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
One more thing to add, I am a CAD engineer at Chrysler. Although, I'm now working in the design studio, in my previous life I worked in the engineering side of design. I know how this stuff is engineered and everything that is involved in the design of these pieces.
The big block is a great piece and can handle some pretty impressive power numbers, but it was designed in the 1950's with 1950's technology. The GenIII Hemi was all designed on Catia V5 and has gone through countless hours of testing and computer simulated stress analysis using all the latest engineering tools and technology. This is how you can get an engine today that is much stronger and much lighter. This goes for the the GM LS motors and the Ford mod motors too. All of these stock casted components are withstanding 1100, 1200+ horse power and living to tell about it.
Re: single turbo hemi [Re: JackGTX440] #1273664
07/29/12 01:21 PM
07/29/12 01:21 PM
Wisconsin,USA
Bzzzz Offline OP
Bzzzz  Offline OP
Wisconsin,USA
Thank you for the insight..you will have pm!
1984 Dodge D250
Re: single turbo hemi [Re: Bzzzz] #1273665
07/29/12 01:44 PM
07/29/12 01:44 PM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
What the genIII hemi's have going against them is the pistons with high set ring lands and powder metal connecting rods. I would have liked to have seen what the engine in the article would have done with some Manley rods and diamond pistons.
Remember the article in Hot Rod where they did a test similar to this? They strapped two of those chineese 76mm eBay cheapies to a 4.8 LS to see how far it would go before it blew up. It made like 1208 hp and never broke... They ran out of injector before they could break it. Granted, it wouldn't live that long at that power, but it did withstand like 30+ dyno pulls building up to that power level.
The hemi's stock pistons and rods would never hold that. Once most people hit the 500-600 hp mark, the pistons and rods are swapped. BUT, the point of this thread was block strength... so...
Re: single turbo hemi [Re: JackGTX440] #1273666
08/08/12 09:33 PM
08/08/12 09:33 PM
Wisconsin,USA
Bzzzz Offline OP
Bzzzz  Offline OP
Wisconsin,USA
The stock 6.1 crank goes into the 5.7 block or??
1984 Dodge D250
Re: single turbo hemi [Re: Bzzzz] #1273667
08/09/12 10:27 AM
08/09/12 10:27 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mopar needs to get with it and come out with better blocks like GM has done with their LSX blocks for these type of builds.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: single turbo hemi [Re: 6PKRTSE] #1273668
08/09/12 01:33 PM
08/09/12 01:33 PM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
The problem mopar has, is if they come out with better stuff, it'll cost $1,000,000. OR, it'll be next to impossible to get like the aluminum GenIII block and cost more than $1,000,000.
Re: single turbo hemi [Re: JackGTX440] #1273669
08/09/12 02:06 PM
08/09/12 02:06 PM
NY usa
540challenger Offline
NY usa
I hear ya on that... I just purchase the Alum. Gen 3 big bore block I ordered it through jegs got it shipped to my door in about 10 days. They back in stock .....well at least last month anyway
