Engine lose's idle speed when warmed-up #1273199
07/24/12 06:03 PM
07/24/12 06:03 PM
Enfield, Ct
Moe Offline OP
Moe  Offline OP
Enfield, Ct
Driving around once temp reaches about 180° I noticed idle speed drops 500 rpm. It wants to stall. This has never happened before. in 7 years I 've ben driving it.
Never had problems w/ vapor lock.
Fuel pressure fine. Turn-up idle speed. No increase?
If I'm low on auto trans fluid would this do it?
'68 Dart
440 Eddy 800
727 auto
Re: Engine lose's idle speed when warmed-up [Re: Moe] #1273200
07/24/12 09:06 PM
07/24/12 09:06 PM
I'd open up/clean the carb
