what size and backspace wheel ?? mini-tubbed dart #1272921
07/23/12 09:19 PM
07/23/12 09:19 PM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
OK so I was wondering what size wheel and backspacing would I need to put a 29x12.50 micket thompson sportsman street tire on a stock width 8-3/4 in a 68 dart? Anybody running a combo like that? I was guessing a 10" wide rim with a 7" backspacing? I have measured from the frame out to the lip on the qtr and its 0ver 15" wide so should be plenty of room with the right wheel and tire combo. Thanks in advance for any input.
Re: what size and backspace wheel ?? mini-tubbed dart [Re: BEEQUIK] #1272922
07/23/12 09:30 PM
07/23/12 09:30 PM
Toronto
mshred Offline
mshred  Offline
Toronto
7.5" is what I needed with that tire and a stock width a-body 8-3/4 housing and a 15x10 wheel (not many choices there either)...needless to say I got rid of those tires in a hurry when all they did was spin no matter where I used them
Re: what size and backspace wheel ?? mini-tubbed dart [Re: BEEQUIK] #1272923
07/23/12 09:33 PM
07/23/12 09:33 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
chris, what you are saying is spot on. a 10" wheel with 7 " rs will fit with room to spare.you can fit an 11" wheel with 7 7/8 rs if you really need the width but a 10"will give you more room
Re: what size and backspace wheel ?? mini-tubbed dart [Re: mshred] #1272924
07/23/12 09:36 PM
07/23/12 09:36 PM
fresno ca
mikeysmopars Offline
fresno ca
Same here !5x10 7.5 backspace using 295 50 15 eagle but had a lot more room inside
Founder and CEO of the Central Valley Mopar Drag Pack
Re: what size and backspace wheel ?? mini-tubbed dart [Re: mikeysmopars] #1272925
07/23/12 10:06 PM
07/23/12 10:06 PM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
OK next question- anybody got a pair of 15x10 alumastars with a 7" backspacing?
Re: what size and backspace wheel ?? mini-tubbed dart [Re: BEEQUIK] #1272926
07/23/12 10:10 PM
07/23/12 10:10 PM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: what size and backspace wheel ?? mini-tubbed dart [Re: Triple Threat] #1272927
07/23/12 10:46 PM
07/23/12 10:46 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
MY car had 12 X 15 Centerlines with an 8" backspace on a stock width 8.75 A Body rear when I got it. Its a mini tubbed to the rails '73 Dart Sport. It also had 14.5 x 28 Quick Time Pros which have a 12.5" tread width. Hope this helps-Randy
Re: what size and backspace wheel ?? mini-tubbed dart [Re: BEEQUIK] #1272928
07/23/12 11:40 PM
07/23/12 11:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mini-tubbed and leafs moved into the frame rails w/stock width a-body 8 3/4 here and my last 12" rims had 7 1/2" bs w/a bit of room to spare and now my 10`s are 6 1/2 bs and fit much better w/a 29x13.5 Hoosier QTP`s which put 11 1/4 inches on the ground.........
Re: what size and backspace wheel ?? mini-tubbed dart [Re: Triple Threat] #1272929
07/24/12 02:06 PM
07/24/12 02:06 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
I Shoulda never sold it. . .
How's the bodywork coming?
I'm Gumby dammit!
Re: what size and backspace wheel ?? mini-tubbed dart [Re: BEEQUIK] #1272930
07/24/12 05:50 PM
07/24/12 05:50 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
15x12 steelies with 12in slicks----I have 5 1/2in backspacing---seems enough to me.......
Re: what size and backspace wheel ?? mini-tubbed dart [Re: BEEQUIK] #1272931
07/24/12 06:40 PM
07/24/12 06:40 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
I might just know where there is a nice complete Dana and Holeshot wheels.
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: what size and backspace wheel ?? mini-tubbed dart [Re: Plumb Wired] #1272932
07/24/12 09:58 PM
07/24/12 09:58 PM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
that sounds great except I know where it is and who I would have to go through to get it!! Besides,that car WILL rise again!!! I don't need a dana right now,and funds are tight.Trying to get a little done so I don't go crazy. How much??
Re: what size and backspace wheel ?? mini-tubbed dart [Re: BEEQUIK] #1272933
08/05/12 11:28 PM
08/05/12 11:28 PM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
Anybody know if a 15x9.25 wheel with a 6 inch backspacing would work? these are 29x 12.50 m/t sportsman tires.
Re: what size and backspace wheel ?? mini-tubbed dart [Re: BEEQUIK] #1272934
08/06/12 03:13 AM
08/06/12 03:13 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Dont forget to go to the manufacturers website and get the EXACT section width .
Right now on my dart-- Ive got 29x11 Eagles on a 10x15 Weld with 7.5" b.s.
springs moved in and mini tubbed. PLENTY of room both sides .
Re: what size and backspace wheel ?? mini-tubbed dart [Re: 493_DART] #1272935
08/06/12 12:32 PM
08/06/12 12:32 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I just did the same thing. Mini tubs and springs are moved in. I went with a 15x10 by 7.5" BS. I still have plenty of room on both sides.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: what size and backspace wheel ?? mini-tubbed dart [Re: BEEQUIK] #1272936
08/06/12 02:31 PM
08/06/12 02:31 PM
Muncie
Racebuddy Offline
Racebuddy  Offline
Muncie
I have 10 inch Bogarts, 7 inch BS
on 12.5 wide 29.5 tall Phoenix slicks on 67 B-Body.
FOR SALE $550 wheels/ tires/ center caps
pm me
